Lens Markings
Guest Him
I have a small question which is puzzling for the moment, I wonder if mine 35mm is like the pound coins worth hundreds of pounds for being different! One of those lenses is not marked at the bottom You can clearly see the others 14mm/23mm/56mm/90mm but the Super EBC 35mm 1:1.4 does not have 35 engraved upon it above the rear cap.
Now is my copy of this lens unique? A grey import? Or perfectly normal? Anyone else with the 35mm has yours the marking or not?
