Canon 1Dx Mark II to X-T2
zimmanj
I am located in Montreal Canada. I just received my X-T2. I'm looking forward to the change from my Canon system.
I haven't fully committed to the X-T2 because I can't seem to find any good information on shooting birds in flight which is something I enjoy to do with my Canon. I have the Fuji 100-400 lens, 1.4 extender and power grip. I have tried to capture birds in flight but have had very little success. I am hoping someone has a bit of experience and can guide me through the proper set-up of the menu. Once I can master this I will be ready to make a full commitment to the Fuji system.
