Pixel problems??
KP Ho
I start notices large black pixels from my XT1 and X100F when enlarge the image to 200% in photoshop. Is it normal?
Nope that is not normal -- appears to be an artifact of the CFA. Is this a camera generated JPEG or a JPEG from a processed raw file and if so from what software?
I converted my RAW through Adobe RAW converter and then I have it opened in Lightroom. Should I use a updated Lightroom(like Adobe cc) to process my RAW files from now on?
Don't really know what is wrong yet. Next step is to let someone else examine that raw file. Open a free Dropbox account and upload the raw file. Then place a link to the raw file here. I have multiple RAF capable raw converters -- take a look for you.
I don’t understand, what I see is a few darker blobs, is this not simply dirt on your sensor?
Take a picture of a white surface and enhance contrast if you see black globules it’s dirt otherwise it is something else
I mainly use Adobe DNG converter and I just double checked my converter is capable for X100F. Do you guys think I should use that RAW file Converter from Fuji?
OK -- definitely a demosaicing error. You're seeing an artifact of the CFA generated by a failure in the demosaicing algorithm. It's your processing software. From what you've written so far here's what I assume: You have an older copy of LR/Photoshop which does not support your camera. So you're using the Adobe DNG converter to generate a DNG file and then you're processing that DNG file with the older LR/Photoshop. Your older copy of LR/Photoshop is the point of failure.
For reference: processing using Fuji Raw Converter: clouds
Your options: You can keep doing what you're doing but you need to make a change in the Adobe DNG raw converter: Open DNG converter and under item #4 click the box Change Preferences. Click the dropbox Compatibility and select Custom. In the dialog that pops up check the box Linear. You're good to go. The DNG files will be larger but they'll work.
You can demosaic the RAF files wth other software. Fuji supplies a version of SilkyPix with the camera -- I used that for the above file. There are lots of other options from free to $$$.
Edited by graflex
Thanks man! It works, I can see the difference now. Thanks again!!
Edited by KP Ho
    • Hello, If you look in the top right-hand corner of each posting, there should be three dots in a row, like this —>  …  <—, click on them and after a moment or twelve, a small menu should drop down from the dots, the last entry in the menu is ‘Edit’. Choose that and after a moment or three you should be in edit mode for that entry. Note: Only you can edit your entries.
    • Jerry I found out it's a Cherry Blossom but I can't figure out how to edit it.
    • What is most ironic about this is that there must be many of us here that would be interested in significant ads about the products we're discussing. I would be. I normally hate ads, but relevant ones here would actually be somewhat welcome. What are the recent new Fuji product announcements? Is anybody offering a sale? How about 3rd party products? I mean, I actually want to spend money, more or less.
    • I don't think I have your answer, but it's worth trying. It's been a few days, are you still struggling with this? I've used Acquire (on an iMac) and an X-T4 (also an X-T5 and an X-T30 ii) and it worked, at least as far as backing up. No error messages, and a computer file with stuff in it. I understand you get an error message when you attempt to restore the camera from a backup, but, does it look to you like the backup phase is working? I mean, do you get a saved file and no error messages? Do you have any other Fuji cameras, and does it work for them? I have had problems getting Acquire to detect the camera. I did all manner of playing around with starting the software, plugging in the camera, and powering the camera on, in various orders (including what the instructions say). I always got it to work eventually, but it took lots of playing some times. Lately it fires right up. Somebody here commented on this difficulty and the security obstacles in the computer. Are you getting a connection easily, or after trying things, or not at all? Does Acquire show your camera model and the few settings it displays correctly?
