No of course no autofocus, and not only with metabone but with any current production of adapters because no adapter has electric contacts able to carry the autofocus between lens and body.
Not only but NO other communication between lens and camera is possible!
You won’t have any of the things that you are seeking.
There are some experimental adapters with these electrical contacts but they will be so expensive that it makes no sense to use them. They are being developed for the Fuji GFX.
Also, there are no reasons to spend the kind of money that metabone adapters or novoflex command.
K&F are made very well and cost a fraction of the price. This is also true of the “ speed booster” adapters.
    • More testing of lenses today.  Nikon 70-200 f/2.8 IF ED VR (same applies to VR II) - dreadful. Heavy vignette at all focal lengths and apertures. Obvioulsy fine in 35mm mode.  Nikon 70-200 f/4 - some vignetting at full frame (similar to 24mm f/1.8 and Sigma 105 f/2.8 so probably correctable or slight crop to 80-90MP). Perfect in 35mm mode.  If weight is an issue for you the kit 35-70 Fuji GFX lens is lightweight and better than you might expect but isn't a fast lens at f/4.5-5.6
