Fuji XT-1 Macro Setting
bernphys
It is no longer there (for 2 years now) or needed since May 2015 several firmware updates ago with version 4.0, after that it became automatic.
http://www.fujifilm.com/news/n150511.html
The firmware update introduces the Auto Macro function, which automatically switches the camera into the Macro mode while maintaining the conventional AF speed. You no longer have to press the Macro button to initiate a close-up shot. This update eliminates the Macro function assigned to the Macro Button, allowing you to assign a different function to the button.
Also the type size that you need  to type text on this forum needs not being so large
    • I do not use Flickr, so I do not know what their BB code is. All I did was copy the second link you provided, (starting at https: and ending at  _k.jpg — leave off the [img] and [/img] tags) and pasted it into the message. After a moment, a message popped up asking if I wanted to paste it as the image or as a plain link. I did this twice, the first time I had it paste in as the image and the second time as a link. Nothing fancy or tricky.
    • So do I just copy the BB code from flickr and paste it anywhere on the page like other forums or is there some other trick I need to perform to get it to post?
