Hi everyone, I’m hoping you can help me with an issue I’m having with my images.
Every photo I take with my Fujifilm X-T2 has visible spots on it (as shown in the attached photo). Because of this, I have to spot-heal all my images in Lightroom just to remove the spots, which is very time-consuming.
I’d really appreciate any advice or suggestions on what might be causing this and how I can fix it permanently.
Thank you so much for your help!
    • (Open Thread) Not a winter landscape, but still cold.
    • agreed on the upload but based on the location and number it sounds exactly like the storage slot 1 status icon
