Hi all,
I was looking for a battey replacement/upgrade for my X10.
Would the Lectrosonic LB-50 1000mah work here? What are you guys using instead?
Budget isn't too much of a consideration, just wanted a reliable upgrade.
Thanks!
To directly answer part of your question, the voltage is safe and the current seems sufficient. The images of the LB-50 look okay, but to be certain it will fit, you need to check the dimensions closely, the corner notch in particular.
Why not pick up a couple of the NP-50 replacement batteries? They are readily available and low cost (I know you said budget is not much of a consideration). That way you will have plenty of back up battery and use the spare change to get another storage card.
Edited by jerryy
