Hello to all, I’ve just entered the Fujiverse after sixty years of shooting with other systems. Both film and more recently digital. I think we’re gonna like each other…✌️🇦🇺
    • Somehow my shutter fell off my X-a5. On Amazon, there are a number of camera shutter buttons for Fuji cameras. My first thought was that I could just purchase one of these and be ready to go. But after checking these out, it appears that these shutter buttons are for cameras with a screw hole in the shutter button and the X-a5 doesn't have this kind of shutter and even if it did, the shutter is gone.  I called Fuji and they wouldn't even discuss it or accept my photo above to view it, they said I had to send it in which I'm not ready to do. One more update... I just stuck a pin through the center opening of the small center hole and the shutter activated and took a picture. Seems like there could possibly be something to attach there, like a replacement release to remedy this. Based of my explanation and what you can see on this scan, can someone advise me what I need to purchase or what I need to do to resolve this? Thank you.
    • Dear Fujifilm team,im a satisfied user of the Fujifilm X-S10 a compact but powerful camera that i appreciate very much. However , I would like to propose a firmware update that i believe would be greatly appreciate by many users Introduction the " Pixel shift-multi-shot " and Unlocking video recording in 4k/60p with 1.2 crop . Thanks for your attention,greeting from a passionate FujiLover 🙏🙂😌🌺❤️
    • Yes Is some small amount leftover from the spot i cleaned. Inside only very less point of dust,yes my be are from manufacture Is very microscopic. anyway on pictures i not see dust and i not see the spot i clean. thankyou so much for your reply Is beautiful im Happy.Have a good day
    • Are you certain the spot is on the inside and not some small amount leftover from the spot you cleaned? Maybe try a different brand of lens cleaner, but make sure it is safe for lenses so that the lens coatings are not removed. Even weather resistant lenses can get dust inside, the seals can only keep out so much dust and zoom lenses are known to get dusty on occasion. More so than prime lenses do. Weather resistant means more sealing, but achieving perfect sealing is tough to get. It is also possible the dust has been there from the time it was manufactured and you are only now noticing because of the white dot. Does the dust show up in any of your photos? As far as cleaning cost goes, your local camera repair shop will be able to give you some estimates, prices will be different depending on where you are.
