X30 Display and EVF flickers when zooming -
Hi,
Does anyone else notice the display flickering during zooming in AF-S mode?
Can someone else with an X30 please check if yours does the same thing.  If it does, it may be a design 'feature', if it doesn't then I will need to send my camera back as it appears to have a fault.
Whilst I am zooming from wide to tele, with shutter release half-pressed and the focus is thus locked, I hear a sound (like the autofocus-mechanism sound) from the front of the camera.  Each click is accompanied with a bright flicker on the screen.
This is repeatable.  When zooming from wide to tele it clicks 3 times, through the range from wide to tele.  it does it every time. When zooming the other way (with shutter release still half-pressed), then I hear the same three clicks, but there is no screen flicker in that zoom direction.
I am assuming the the X30 is re-focusing during zooming whilst the shutter is half-pressed.
The flicker happens in the EVF as well as the LCD.  I have IS switched off, and also advanced anti-blur is switched off.
It is not related to fluorescent light flicker, as it was doing it in daylight this morning.
It does not flicker if focus is locked with AF/AE lock button.
It does not flicker in MF when zooming.
Therefore, I deduce this to be autofocus-related, and may be some interference between the AF-mech electronics and the display.
Firmware was 1.01, I updated to 1.03 and the behaviour is the same.
Can anyone with an X30 please check your camera's behaviour for me please?
FWIW, the X10 doesn't do that, probably because it won't refocus during zooming with the release half-pressed.
Thanks in advance.
      Ohio River, Kentucky - Indiana, USA Ohio River, indiana - Kentucky, USA
    • Interesting, and a bit subtle. I also think it'd be better to activate on a half press. But there seems to be good reasoning behind a number of other choices, so I wonder if there's a good reason behind this one and we're just not seeing it. To some degree IS goes on and off like AF does, but this is an exception, isn't it?
    • I couldn't find my manual so downloaded a PDF copy and did some searching.  From p146 of the manual, regarding Shooting Only stabilisation: "Image stabilization enabled only when the shutter button is pressed halfway (focus mode C) or the shutter is released." So it appears that the camera is 'working as intended' and that in AF-S the stabilisation mechanism kicks in only as you release the shutter. I think I would prefer it to activate on a half press, like it does in AF-C.
    • Sometime a short break can help to phrase things so that they do not sound annoying, Well that is the hope anyway, so here goes. Having that meter would be nice as well as having the histogram. But having them or not is a minor consideration in terms of what you are wanting to do because the app does not work with intervalometers. The only way you can get a time lapse sequence using the app is to manually click the shutter button, wait then click it again and so on. Even if the meter were there, you would need extremely fast reflexes to see and react to a lighting change by changing the settings and then going back to clicking the shutter button. Doing that for hours would be a feat indeed. The equipment you mention does this by analyzing several past images and predicting what settings to apply to the next incoming image. Right now the app has the live view which will tell you if an area is over or under exposed, but as far as what you are wanting to do without being able to connect the app to an intervalometer, well …
    • I want to check with you guys on how image stabilisation is meant to work on the XT4 and whether I might have an issue. I was out with the camera yesterday with the 80mm macro lens, which has OIS, and the 1.4 Teleconverter and did some tests to see how good the stabilisation was performing by pointing at random objects/general landscape.  On the lens I had the OIS switch turned on and I selected the stabilisation to be always on in the menu option and was suitably impressed with how much camera shake was reduced.  However, when I went in the menu and selected Shooting Only for stabilisation I noticed something odd.  My understanding with this mode is that when you half press the shutter release the OIS is meant to turn on and stabilise the image just before completing the shot.  With the focus switch set to Continuous AF this is exactly what happened - shaky image, half press, stable image.  But, if the focus selector switch is set to Single AF I half press the release and I get no stabilisation.  The focus locks and the exposure locks but the image is still shaky in the viewfinder. I swapped out the lens for my 16-80mm kit lens and this performs exactly the same - no image stabilisation with Single AF selected, so it appears to be something to do with the body and not the lens. Is this normal?  I would be surprised if stabilisation only kick in when you fully press the shutter release because some shots are taken with tiny fractions of a second of exposure and the mechanism will still need a finite time to engage.
