Bizarre shutter speed readings on EVF & LCD
Are you writing in backup or sequential mode? If you are writing in sequential mode then its going to write first to the primary card and then switch to the secondary card. The speed of writing from the buffer to the card would be slower when the primary card is full. If you are writing in backup mode then things will slow down if you are shooting bursts AND the bursts fill the buffer - at that point write will be at the speed of the slower card.
By ronphotohawaii · Posted
So does the CF Express take the initial data from the camera and then later on the SD card catches up? I've been using CF Express only but it's a pain in the butt to use a card reader all the time. I'd rather just use a secondary SD card for compatibility issues, but would my buffer rate be effected? -
By Michel Pierfitte · Posted
Hi everyone, Nice to meet you, I'm new to the forum and love Fuji. I live in France near Paris. I'd like to share a moon shoot dated march 2023 made with X-T5 with XF 150-600. Enjoy the mineral moon !Welcome, dear visitor! As registered member you'd see an image here…
I have one of those. I use it a lot for my camera lens based images. It is light, weight wise, which is good for travel/carrying, easy to use and works well. Hopefully, the weather will let you outdoors at night and you can have some fun. Right now, the Orion Constellation is readily visible with all of its nebulae and galaxy season (Spring) is coming. p.s. Coming up on March 13/14, 2025, is a Lunar eclipse: https://www.timeanddate.com/eclipse/lunar/2025-march-14
