Hi,
Beeing often a street photograph I then want that my camera keeps silence.
On the X70, I have not found a quicker way that going in the menu and select "sound configuration" then changing camera sound and shooting modes to "not".
I am looking for a direct way to switch to "silent mode" as I had in  my X20.
Does anyone know if such a way exist on the X70 or a way to change parameters in order to come to the same result ?
Thanks for help
