LCD/Picture Counts
I have an X-T5 with three lenses: XF18 1.4, XF33 1.4 and a 55-200. I was using a Bellingham Hadley Small bag when I only had the 33 and 55-200 lenses, but having just bought the 18, that bag is too small without having the 33 lens laying down instead of standing upright. I had a Domke F6 from before and tried that one. The way it’s configured, I can put two of the lenses in their 4 pocket holder, filling the other two with flash and accessories, and the camera with a lens in their unpadded section of the bag. I’ve tried buying a padded insert , but the camera and lens wouldn’t fit in it, so if I’m using the bag, it’s in the unpadded section. Does anyone have an F6 Domke bag and keeps their camera in that unpadded part with the lens on? Thanks
When did the problem start, and how did you transfer the file—direct connection, cloud, or another method?
Thanks, but none of the options quite do what I want. EVF only + sensor displays the taken image on the EVF screen not the main screen. EYE SENSOR + LCD IMAGE DISP. keeps the screen turned on unless I'm looking through the viewfinder.
The user manual explains how to configure image review on the LCD screen. https://fujifilm-dsc.com/en/manual/x-t5/menu_setup/screen_set-up/#image_disp
Hello, I moved from Canon to Fuji and I'm impressed by what a difference it makes. I have one question though. In canon (5d ii), I was very used to a flow of 'take a photo through the view finder' - 'look at result on screen'. In Fuji, I can't seem to figure out a way to keep the screen off (to conserve battery) for 'live mode', but still have the results display there once the photo is taken. Any way to set it up that way? Thanks
