Turn off front command dial?
By Astigmatism · Posted
Just as a general strategy, I think the Custom Settings are good for recovering from the frequent problem of some unknown setting getting accidentally changed. Don't know aboutXH2S, just X-T3,4,5 cameras. I have C1 set up as my typical use setup, and could just hit that to get most settings back where I expect/understand them. C2-C7 I reserve for special uses. Any thoughts on this, folks? -
Come back and take a look again in the Fall, especially in the early misty morning. I think you will like what you see. Late afternoon will also be a treat in a different way.
By jakabasej8 · Posted
Could be tied to Burst mode settings—some modes limit size options -
In backup mode, your write speed is only as good as your slowest card, especially during bursts -
Hey, This question may have been answered already but can the XH2 output 4k pro res raw to the Atomos ninja v or is it limited to only outputting the 8k pro res raw? If its capable of 4k,6k pro res raw etc, is there a firmware update allowing for this? Thanks!
