X-T2 and 18-55mm
Hermann
Hello everyone,
As a future newcomer to Fuji X systems, I wonder if a should take the X-trans III or take a cheaper X-trans II (X-T1 for example).
What I know is that I will probably use only the 18-55mm.
So here is my question: do you think that the increased resolution of the X-Trans III (24Mp vs 16Mp) is useful with a such lens, which is quite good but not stellar? Is the 18-55 sharp enouth to benefit from these additional megapixels?
Thank you very much!
You're unlikely to notice a significant difference between 16 and 24 megapixels with any of Fuji's lenses (zooming in to 100%). And you're certain not to notice any difference at normal display and print sizes. This isn't to say that the lenses aren't sharp enough for 24MP---they are. It's just that the 8MP difference is not very significant.
The new cameras are faster overall and have better autofocus performance and much better video quality. But for stills, and especially for slower paced shooting, rest assured you're not missing much by getting one of the 16MP bodies. I wouldn't pay the full retail price for the X-T1, though.
I agree with majority of your points, Kim, but you CAN see the difference in resolution between the two cameras on a 27" 5K Retina iMac. That being said, I fully agree that 16 megapixel resolution is plenty for the vast majority of applications and/or prints.
Edited by Puma Cat
I'll take your word for it. My basis of comparison is a 50" 4K (UHD) screen, looking at center frame crops with my face about 1.5' from the screen (same subject, framing, lens). Yeah, I can see a very subtle difference in sharpness in this scenario. But if I was comparing two images of different subjects, I couldn't tell you which came from the X-Pro1 and which came from the X-T2. They're extremely close in IQ. If we were talking 16MP vs 36MP, it would probably be a different story...
Even with the same subject, fit to screen (i.e. zoomed out), I can't tell the difference (4K is only 8MP after all)...
Lenses almost always beat bodies.  I went with an X-T1, because I don't have the lenses yet.  Once the lenses I need are in place, I may go with the X-T2.  I will most likely wait till there are good used ones for a lesser price.
I would love to have a little faster focus, but only place I've seen this is trying to get the limited depth of field shots of pets looking up.  Sometimes, I'm 1/4 second too slow with the whole process.  Not sure if the X-T2 would help or not.
It partially depends on how you use the camera. Obviously the X-T2 offers improvements, but the X-T1 is a fantastic camera. If you need video, the faster AF, and/or the much easier to adjust focus point adjustment, you should go with the X-T2. If not, the X-T1 would be a good choice. I had bought the X-Pro2 earlier this year and got used to the joystick and better AF. I can't go back now.
    • Hello. Thankyou,now Is all more clear: I have take some time in you link. Let tell you.i was totaly forget this machine have "compress picture option" and not Only "compress lossless" anyway not change the experiment. RAW  and this last two format look like same result about Number of recording picture. Can tell alll results in this: in raw you can make 17 pictures for second.Is wrong.Is about One single Press and wait buffer. Full 30/20/10/8 not change. After 17 Need Press again. You not can Press before "redgreen light recording Is on"   With preshot you can have 25  are more 7 pictures  The story change Only in jpg shot only. In jpg at 30 you have 30 picture but redgreen light off very Fast so you can shot very quicly. At 20 shot Is about start look like infinite shot. 150 picture +- So the best performance are this last One  I want take a shot about Italy cyclet Just for passion. I think i Will use this last setting.
    • I do not use Flickr, so I do not know what their BB code is. All I did was copy the second link you provided, (starting at https: and ending at  _k.jpg — leave off the [img] and [/img] tags) and pasted it into the message. After a moment, a message popped up asking if I wanted to paste it as the image or as a plain link. I did this twice, the first time I had it paste in as the image and the second time as a link. Nothing fancy or tricky.
    • So do I just copy the BB code from flickr and paste it anywhere on the page like other forums or is there some other trick I need to perform to get it to post?
    • All software is the latest between camera and app. All settings are correct on camera. I have both lossless and uncompressed RAW files on the card in the camera. I have been up and down every reddit thread to no avail and am losing my mind… I’m doing all of the right things. It even sees my camera. It just doesn’t create the “drive” for it (see attached image screenshot).  Please Help!
    • Not sure how to delete threads, but I figured out what was wrong. In short, I was partially misunderstanding the view-mode's function. Also, the "+LCD Image Display" part requires that you have the Image Disp. setting set to anything but Off. Then it will display your last image on the LCD. If it's off, it's behavior will be exactly like the plain Eye Sensor setting.
