Last week I picked up an X-E2s with 23 1.4 and am still feeling my way around it.
One thing I haven't figured out yet is why setting the focus control to C puts the camera into a MF mode with focus check, according to the viewfinder display.
I've reviewed the manual and can't see any explanation for what's going on. Can someone please set me straight? Is there a setting I need to have in place in conjunction with C for continuous AF to work?
    • More testing of lenses today.  Nikon 70-200 f/2.8 IF ED VR (same applies to VR II) - dreadful. Heavy vignette at all focal lengths and apertures. Obvioulsy fine in 35mm mode.  Nikon 70-200 f/4 - some vignetting at full frame (similar to 24mm f/1.8 and Sigma 105 f/2.8 so probably correctable or slight crop to 80-90MP). Perfect in 35mm mode.  If weight is an issue for you the kit 35-70 Fuji GFX lens is lightweight and better than you might expect but isn't a fast lens at f/4.5-5.6
