Concert Photography (open thread)
Phil
Concert with poor green light from projector. ISO 3200; f2,8; shutter 1/250; 140mm.
Edited by hildasea
Los Almiros Festival @ Greece
36383031025_1cf9d6e9c1_b.jpg_DSF2864 by miltos, on Flickr
36299333642_2d616a74c1_b.jpg_DSF5275 LAF 2017 co by miltos, on Flickr
36421808676_8d51afa9a5_b.jpg_DSF2408 LAF 2017 co by miltos, on Flickr
36007929780_0f9fcc0865_b.jpg_DSF5208 by miltos, on Flickr
36238306992_0288974249_b.jpg_DSF2955 by miltos, on Flickr
35547094064_05710c7bc9_b.jpg_DSF2658 by miltos, on Flickr
36246324031_5e88fa98a9_b.jpg_DSF2241 by miltos, on Flickr
36358133515_5089251a15_b.jpg_DSF2187 by miltos, on Flickr
35597494153_2b5572de6d_b.jpg_IMG9987LAF 2017 by miltos, on Flickr
36236545782_0c38909ab6_b.jpg_IMG9989 LAF by miltos, on Flickr
    • Some elements in (autofocus) lenses are „floating“, so I guess what you are experiencing is normal.
    • How do I turn off the electronic shutter in the menu - the option is grayed out and I cannot select the mechanical option
    • I'm having trouble finding a way to attach a right-angle viewfinder to the Fuji X-H1 camera. Does anyone have experience with how the angle viewfinder behaves in combination with the EVF? Is the Minolta frame diameter of the right angle viewfinder suitable for attaching to the Fuji XH1 (or XT1, 2, 3, 5)? Does anyone have knowledge about which eyepiece is compatible with the Fuji X system? Thank you in advance for any assistance and information you can provide.
    • I purchased a gently used XF 80mm f/2.8 aspherical macro for my X-T5. Not being familiar with this lens but having had experience with the Leica T mount 60mm macro and Canon and Zeiss macros, I was surprised that I felt what might be best described as a loose lens element that shifted when I tilted the lens, even before being mounted to the camera. In manual focus mode, the lens is fine, but there is a distinct “wobble” when the lens is in autofocus mode. I reported this to the company (I bought it from KEH), and they agreed this was odd and accepted it back for a full refund. I just got a replacement lens and the same thing is happening. I’ve never had an experience in which I feel a lens element loose inside the housing. Is this normal? Should I return it (again)?
    • Old post but hope this can help. You have to make sure that exp. comp. is set to zero in P, S or A mode before you go in to manual mode. If the comp is set to, let say +5, and this is of the range for the settings in manual mode, twisting the comp dial (left dial) want do any changes.
