Lajoie lake BC Canada
Ex2 with 55 mm 1.8 super takumar M42 at 2.8 F
Same Kiddo !
X E2 with the FX 90 f2
Love this lens, so sharp!
XE2 with XF 14 mm at f 2.8
    • More testing of lenses today.  Nikon 70-200 f/2.8 IF ED VR (same applies to VR II) - dreadful. Heavy vignette at all focal lengths and apertures. Obvioulsy fine in 35mm mode.  Nikon 70-200 f/4 - some vignetting at full frame (similar to 24mm f/1.8 and Sigma 105 f/2.8 so probably correctable or slight crop to 80-90MP). Perfect in 35mm mode.  If weight is an issue for you the kit 35-70 Fuji GFX lens is lightweight and better than you might expect but isn't a fast lens at f/4.5-5.6
