I like the odd macro shot, but don't want to spend money on a dedicated macro lens, so I thought about using one of the extension tubes from Fujifilm with my XF 35mm f1.4. However I don't quite understand what is meant by working distance when the tube is attached. I have looked at the diagram Fujifilm has made explaining the working distance for their different lenses with either the MCEX-11 or MCEX-16 extension tubes.
Would you be so kind to explain (in layman terms) what is meant by working distance? How far from the fromt element should my subject be and how far away from the front element can it be?
Thanks.
at the bottom of the chart you can read:
Working Distance: Distance from the top of the lens barrel to the subject
Shortest shooting distance: Distance from the image sensor to the subject
So the working distance is the distance between front lens and subject and the shortest shooting distance is the distance between focal plane (where the sensor is) and the subject.
Here is the chart with all distances for each lens.
http://www.fujifilm.com/products/digital_cameras/accessories/pdf/mcex_01.pdf
Just as an added note, don't bother with Fuji's own extension tubes. There's no glass in an extension tube, and Fuji's AF system is such a simple focus-by-wire arrangement that there's no downside to using a third-party set of extension tubes. The Fuji ones cost about 3-and-a-bit times as much for one tube as a set of two third-party ones costs, and having tested out both the Fuji extension tubes and several third-party versions, I've found no difference in AF speed. The only difference I've noticed is the smallest Fuji tube is 11mm, while the smallest third-party tube is 10mm. That's it. If you buy the two Fuji tubes you're paying basically 6.5x more more for what is actually a fractionally less versatile set.
Edit: While I'm thinking of it, it's wise to not buy any of Fuji's own accessories, other than the teleconvertors for the zooms and the wide/tele convertors for the X100. Everything else contains no glass and no reason to pay Fuji's massively inflated prices.
Edited by aceflibble
hello aceflibble,
would you kindly point me to some third party macro extension tube for fuji x series you successfully did try?
I saw this: http://www.amazon.com/product-reviews/B014EV3Q4W/ but I scared due to awful user review!
thanks Sandro
The one I've ended up using myself is called Viltrox—nope, I've never heard of them before, either—and I picked them up after a fellow local X-shooter lent me his set. They're on Amazon, just search for Viltrox on whichever version of Amazon is relevant for your country. Two others I can recall were called Fotga, who make several Fuji accessories and theirs worked fine, and a set I can't remember the brand name of but their metal parts had funky red anodising, so they should be easy to spot.
I've tried five third-party sets in all and not noticed a problem with any of them, but for the life of me I can't remember the names of the other two. AF worked fine, exposure metering worked fine, all feel equally secure. The Fuji ones have  slightly nicer paint finish to them, obviously, but that's all that the premium price gives you.
I guess I should add, in the interest of fairness, that this doesn't just go for Fuji. Extension tubes are one of the easiest and cheapest accessories to make, for any mount, so there's no point buying official Canon/Nikon/Sony/etc ones, either.
Thanks a lot for your useful information! I'll give it a try
Edited by sandroamt
  • 11 months later...
yesterday Friday 9/6/17 took delivery of extension tubes 10 and 16mm long Trade marking DG they fitted on to the XT-2 and the 50-140 Zoom easily. With the setup supported by the lens mount all worked well, there was some slackness between the body and the tubes.  For the hell of it I fitted the 2x Fuji converter directly to the body then both extension tubes set the camera on auto focus and auto exposure basic settings and the Zoom at Max, in effect a 280mm lens with 10+16mm extension tubes. The purpose of this quick test was to see how usable the setup was, I am pleased.  Not much of a financial risk at $10 for both tubes.
In my experience there is no point in putting a link to where I got the Tubes from as the price and availability on Chines web sites varies so much on a daily basis. I have used Aliexpress a lot which is Hongkong based. If you are new to shopping on-line always look at the price and shipping costs(if any) my tubes were $10 free shipping the same tubes are listed at very different prices. {Needless to say the normal security arrangements need to be taken}.
I've got some cheap Chinese tubes, for about £12. They work great and are stackable. Full electronics so the auto focus works. With them both on the focus point is often inside the lens hood on shorter lenses. This gives light issues but you can just use the thin one.
Look at this on eBay http://www.ebay.co.uk/itm/371947783335
Sent from my ONEPLUS A3003 using Tapatalk
I've got the 11mm tube. I don't really have an interest in macro but I'll use it if I need to. For people that do have a real interest in macro work a real macro lens would be about a thousand times better. It's sharper, and easier to focus with then an extension tube. Stacking extension tubes only further deteriorates the image quality. But, an extension tube is an excellent el cheapo solution to dabble with macro. :-)
  • 2 years later...
If you add extension tube to the lens the AF might work only on the "working distance" (the distance between lens front element and object). Accordingly to the chart (https://www.fujifilm.eu/fileadmin/countries/europe/pressimages/DSC/Nov2014/MCEX-table.png) working distance for MCEX-11 and 18-55mm is for wide end - 11mm and for long end - 91mm, but I'd say forget about AF and use manual mode. Just slightly moving your camera back and forth check the focus picking.
