Hello all,
I own a GFX50S II and would like to transfer pictures from my camera to my PC using a wireless connection (Wi-Fi).
It seems that the PC application PC Autosave could do the job, I can't have it working...
Is this app really compatible with GFX50S II?
Is there any alternative?
Thanks in advance for your replies.
Ayapos
Hello all,
I have worked on this topic, it turns out that:
- One can transfer JPG files to any smarphone/Tablet running with Adnroid,
- It is then possible to set an FTP server on the smartphone/tablet accessible by any PC.
Drawbacks: only JPG and NO RAW can be transfered.
It needs a double wi-fi connection , one for the camera, one for the PC.
Furthermore, I have discovered that the Fujifilm GFX50S II has only a 63 Mbps Wi-fi link, hence a veeeeery slow transfer of the pictures.
It really is a pain in the ***!
Once again, if someone can give me any advices to directly download RAW files to a PC, I'd be very glad.
Thanks in advance 4 ur reply.
Regards,
- Ayapos
Edited by Ayapos
Raw files are considerably larger than jpeg, it would take forever and a week to transfer a batch of them over to your computer using wifi. Although sometimes less convenient, using a card reader or a USB cable connected to your computer, to off-load them will work.
Unless you can coax Fujifilm into building an adapter to use the FT-XH file transmitter with your camera.
Edited by jerryy
Hello Jerryy,
Thanks for your reply!
You're right, RAW files are roughly 100 MB while the associated JPEG only weighs 12 MB.
If I've asked my question it's because the USB connector cap on the body is attached to this body with two thin pieces of rubber (or plastic?) and seem very fragile. Furthermore, the body USB connector has a low insersion/extraction lifetime (100 to 200) . Therefore, the less I use the USB port, the longer the mechanical elements will last.
Back to my proposal - transfering from body to smartphone via Wi-Fi has only a 63 Mbps speed: it means that the transter time would be 1.5 s for each JPEG file which is totally acceptable. The drawback is that only JPEG can be transfered.. Hence my frustation.
Has anyone have other ideas to thransfert RAW files to smartpone or PC via Wi-Fi?
Ayapos
The issue is that unless you find some way to attach a high speed reader driving a super fast wifi chip, you are stuck using the built-in wifi, which is too slooooooow, (to transfer those large files, you really need wifi-6 or the upcoming wifi-7 to have something that is practical).
Using the numbers you've provided, if the built-in wifi were used, it would take about 15 seconds for each raw file, which might be okay for just one or two files, but when you are looking to move several hundred files, that is a lot of time, a whole lot of dead batteries and also is assuming the transfers do not have any troubles -- any noise coming from other electrical equipment such as your or the neighbors wifi and cell phones are noise troubles that slow down transfers.
But the really big problem, to top things off, your camera might cook itself to death from the heat that is generated and kept going though a transfer, that is, assuming the camera's thermal safety routines do not kick in and shut the camera off to save itself.
I am curious, where did you find the numbers for the USB insertion/extraction lifetimes? 100 to 200 seems rather low.
Edited by jerryy
Hmm, a lot of places put the number of cycles at 10,000 (ten thousand):
https://www.anandtech.com/show/8377/usb-typec-connector-specifications-finalized
https://www.content.molex.com/dxdam/c9/c924179b-a897-4f79-a5ae-cfdc94fc73cb/987651-4081.pdf
https://www.cablestogo.com/tech/usb-c
which woul make sense, otherwise all of the various camera manufacturers would have a lot of warranty work on their hands.
Card Readers for now!
Hello Jerryy,
I understand your point of view, nevertheless manufacturer of reseller can not say their product are limited in time or usage. It is not their interest. Once again I speak with a +30 years background in electronics design.
On the other hand, as you say, camera manufacturer have - I think - studied the pros and cons regarding their technical proposals, and their products.
In any case, I still hope s.o. can help with what I consider as an issue 😉
Thanks again for sharing your thoughts and opinion.
Ayapos
Edited by Ayapos
I think you have slightly mis-interpreted what I wrote. The camera manufacturers are using connectors that last a long time.
If they did not, then the cameras would break after a few days or weeks or months of use. The manufacturers would then be forced to take back all of the essentially brand new cameras they just shipped out to dealers and fix or replace them. No manufacturer can afford to do that, they would go bankrupt quickly.
You can use USB-C connectors in the Fujifilm cameras and expect them to last a good long while, and use card readers for the major transfers.
    • Thank you. I am a pathetic beginner- in way over my head with this camera. Your info is great. I will practice this tonight on cars driving by my street.
    • It seems good you were able to find an answer to your question shortly after posing it. As to your remaining question, can you give some more details? Because what you are describing is very unusual. Which card reader were you using to move the images to your computer? Were you double clicking the card’s disk image to open it and then using the finder to select all of the images you wanted to move, then dragging them over to a folder on your Mac? Did you use the eject command before removing the card from the card reader? There are a couple of things to also try. Take a few new images using a freshly formatted card, put the card in the reader. Open the app Image Capture and use it to move the photos. Use the eject command before removing the card and see it the card is still messed up. If so, try again, but this time before putting the card in the reader, slide the write protect switch on the card to the protect spot. [The write protect switch is a small little tab on the side of the card.] Move the images, then use the eject command, remove the card, slide the write protect switch back to the unlock position and put it back in the camera. Let us know how things go — uh yeah sometimes it can take a while to get an answer. https://support.apple.com/guide/image-capture/welcome/mac
    • I reply to myself, as - after searching and experimenting this and that during several days - I found today the reason to my problem... Should I tell that, as I haven't got any comments from you, the community? Ok, jokes apart. THE point is that the option Auto update custom settings under Image quality settings needs to be ENABLED! Well, as the manual is so obscure, not specific, with too short explanations and too general, I needed some 1-2 weeks (of course not day and night to find the solution. Anyway, now my X-T50's ISO setting holds, to that I set it. By the way, the camera with the quality of the pictures, is great!!!! I love X-T50 after my reliable Nikon. Well, one more thing, I would like this working: I transfer pictures to my Mac by using the app Photo transfer by wire because it is hazardous to take the memory card from the camera and put it to my MacBookPro because after Mac's reading the X-T50 doesn't recognise it any more!! Nothing but formatting the card *in my Nikon* helps, to get X-T50 to work with the card. So are there for this second issue any solutions??
    • Welcome to the forum. There are some sports oriented photographers that stop by now and then that may give you better tips. You did not mention your photography background, so please forgive me if I say something you already know. Practice. Practice. Practice. Your son might be happy to indulge this 😀. Set the lens to auto focus and for now, concentrate on the three basic parts, shutter speed, aperture and ISO. Set the ISO around 800 to 1600. This may seem too bright for a sunny day, but it will give you room to use the aperture and shutter speed without the scene getting dark. If the lighting is darker, use ISO 1600 to 6400. Set the f-stop on the lens to around 5.6, this should give you enough depth of field (the sharp in focus part) to get his face and most of his bike — this will also depend on how close you are to him — while blurring some of the backgound. As you get used to what this aperture does at the distance you are from him, try other settings, wide open (the smallest f-stop number) can give you very pleasing results as can f16. Remember you are focusing on him, not taking landscape photos, so the background blurring is going to be different. And the last part, shutter speed. Start around 1/400. The higher the shutter speed, the less motion blurring you get and the more the foreground will seem in focus. This is why you need the higher ISO, because higher shutter speeds will make the image go very dark. Try a bunch of the speeds. There is an art to getting the right blurring for the shot, from none at all to massively blurred. Then back to the practice part. After this, those other things on your camera are there to give you options in your approaches. You might set Auto ISO up so you can concentrate on shutter speed without worrying what rapidly changing sky clouds are doing to the images. Or how to use the back lcd as a focus aid, etc. Bring in these new options in a few at a time. Oh yeah, take the lens off auto focus mode and see how you like that, it does work.
    • Hi, A couple of months ago I picked up my first fujifilm camera, the X-E2s. Been using it since then with a manual 25mm focus lens, works perfectly fine. But recently I've bought a fresh, af lens, the 35mm f/1.8 from ttartisans. And I've been having issues with it. Mainly, I've experienced weird problems with aperature control, since the lens has no aperature ring, its controlled electronicly. When setting the aperature control to manual, the aperature blades move randomly when setting a fixed aperature. The lens is often closed on high f value. This problem really ruins the photos when trying to shoot in low light and I'm trying to set aperature to like f/2 but the lens is still stuck at very high aperature (I can see the blades closed) even though I've set it correctly on the camera. Other times, when shooting in medium to bright light, the aperature keeps changing randomly, even when I set it to manual and to a fixed value. It's almost like breathing. Also sometimes when I get it to move, it seems that the aperature blades can't open beyond something like f/4. It reaches the opening of f/4 and stays there even when trying to open it more in camera. Of course the values in camera can change, the problem is with the lens aperature blades. And so my question is, is it normal, it working this way? This is my first experience with lenses without aperature ring, I don't know about any mechanics that would explain the lens acting this way. Would really appreciate some feedback, I'm pretty new in photography and I'm just trying yo wrap my head around on how to use this beautiful camera. 😎
