F/0.85 lens in Fuji X mount
I noticed this today on Amazon: "Handevision HVIB4085FX IBELUX 40mm f/0.85 High-Speed Lens for Fuji X Digital Cameras".
I know nothing about the lens or the maker, save what it says on the page on Amazon. And of course I'm not promoting it. I just thought it was interesting that there was a lens this fast, and don't think I've seen its equal for our mount.
I did have a single element asphere that was just for one wavelength, for collimating light, so its optical performance would deteriorate rapidly away from the center. It was f/0.67. And I have a paper about a microscope objective design that gave an NA of 0.92 which corresponds to f/0.2, which could be a world record as far as I know. The paper is here:
https://arxiv.org/pdf/1611.02159.pdf
But not anything for mounting on Fuji X cameras.
Just thought it was interesting.
That lens you spotted on Amazon sounds really interesting! I'm not surprised that you're intrigued by its speed, which is something you don't see every day in a lens that's compatible with Fuji X cameras.
As far as the lens manufacturer goes and the quality of the lens itself, I don't have much experience with either of those. However, I highly suggest you do some research and read reviews from others who have used it to determine its performance and whether it's worth taking a chance on.
You mentioned that you have experience with fast lenses, including single element asphere and a microscope objective design with an NA of 0.92. That's really impressive! It's always fascinating to learn about other people's experiences with unique lenses and the optical performance they were able to achieve.
I already have the Fuji 50 mm f/1.0, which I like very much. It's a straightforward lens, not one of those that apply filters or odd optical corrections to modify the bokeh for artistic effect. In an ideal rectilinear lens, the bokeh would have uniform illumination and take on the shape of the iris diaphragm, and I think they can only modify that by introducing aberrations (primarily spherical) or vignetting filters. There's no accounting for taste, the heart wants what the heart wants. My personal taste is for minimized aberrations of all types, and my very rare toying with modification away from that only happens in post on long winter evenings. Given that I already own the lens I own, I don't think I'm buying -- but it is interesting! And I'd love to learn about even faster lenses....
Interesting!
I'm mystified by the statement "A 35mm equivalency would give you something like a 60mm at f1.2, except, it’s still going to be 1.5 stops brighter than an f1.2.". Why does a 35 mm equivalent imply a specific f/ number? This equivalency is simply about focal lengths that would give the same angle of view.
I think it just means that while you are getting a large amount of light because of the f/0,8 , you are going to have some more field in focus than what you would get on a full frame with f/0,8
I’m more inclined in looking at the images which show a lovely focus falloff - but the lens is too expensive for me so it’s all theory :)
    • It is/was not what I was used to (5D3, R6) in terms of color and WB. Using Kelvin manually is just like another top dial. Something to do to get it right in camera.
    • I don't think there are Fuji "FX" lenses or mounts, it's "XF". If I had your camera I would buy any XF or XC lens and expect it to work. I do have an X-T30 ii, pretty similar. I have lots of XF lenses. XC lenses are made by Fuji and are cheaper, if it's cheap you want.  I wanted a lens with very few elements or element groups, and bought a Pergear lens for about $59 new. It only has 4 elements in 3 groups, IIRC. I also plan to use it if I ever think I might ruin the lens, like shooting something dangerous.
    • Buonasera a tutti, qualcuno usa Saal Photo Portal per vendere le proprie foto? Funziona? Grazie,
    • Please help me before I send it back. Do I have a bad copy of Fujinon 33mm f1.4? I find it really soft off center (not even corner). See print screens. I focused on the same spot, just moved focus point. I get same result over and over again. (EDIT: After more testing I find that I can get sharper results off center but it's very inconsistent and not at all reliable. Focusing issues? It's not the camera, Ive have tried it on 3 different cameras)
    • Hi everyone. I'm new here. I recently bought an X-S20. It's really a decent camera but i encounteted something odd. I linked my X-S20 with my phone via wifi using XApp. I enabled Auto Image Transfer Order so that images in X-S20 will be sent automatically to my phone whenever Xapp is activated. When the camera is switched off while there are images queuing to be sent, the indicator lamp on the camera blinks green and orange. I know it is normal since it is only completely turned off until all images are sent to the phone. But sometimes the image transfer is discontinued due to connection problem or else. The problem is, after being disconnected, the camera seems not to identify the disconnection and keeps on blinking green and orange. If i switch the camera power button to ON, the camera will not show any response (but continues blinking). The only way to fix this problem is to take the battery out and put it bavk again. Did anyone also encounter this problem? I would like to know how to fix it.
