Choppy playback in editing
My xh2s footage is playing back rather choppy. I'm sooting 4k 16:9 Mov/H.265 All-I 4:2:2 10 bit 360mbps. I'm editing in FCP on a 2 year old MBP with 8 core i9 32gb of ram and 8 gb gpu. I know the computer can handle this and more. I've tried editing off the internal ssd and external mechanic disk and finally an external ssd. all of them are the same editing experience. Just feel like I'm missing some simple setting in FCP. Thanks
You might want to consider the following:
1) Use optimized media.  These are ProRes files that can be generated inside FCP, or
2) Use proxies.
Incidentally, I too had difficulty editing 4K H.265 All I 4:2:2 10 bit recorded at 360 mbps with FCP.  Playback was choppy, as you have pointed out, so proxies or optimized media were required.  To improve performance I purchased a MBP16 M1 Max, 32 core GPU, and 64 GB of RAM.  I no longer have to take time to generate optimized media.  Also, I switched to Davinci Resolve Studio.  I think it is a better editing experience than FCP.
Hope this helps.
Don
Hs65 files are "delivery" files and are hard to handle for any editor. Its like opening a .rar or .zip file and then doing a bunch of photoshop edits on it, its just not optimised at all for editing.
Chucking horsepower at the problem may help, but the nature of the filetype will probably cause problems quite often, even high specc'd machines can have trouble with them. Doing optimised media helps because it creates a file thats not compressed and good for editing, the downside is the waiting and constant clearing of temp cache on your hard drive.
If you're doing a lot of shooting I'd grab a CF card and shoot in ProRes, it wont have the problems H264/265 files have, its a proper editing codec and will be handled much better when editing. CF is an annoying format to shell out on but if we're this deep with the XH2 then you might as well maximise it with ProRes over CF.... or ProRes RAW / Blackmagic RAW via an external recorder.
What kind of hard drive are your files on? I was having slow playback from my video. I moved clips over to an SSD and things sped up immensely.
Ah, just saw you said you tried SSD. Yeah, switch to Prores in that case. It edits smoothly for me from an SSD.
Edited by ChrisKou
    • HI Rufo, I have changed procedures.  I now use the colors space transform (CST) as my first node.  The CST is set up as follows: - Apply the CST effect to the first node. - Color Space is Rec 2020 - Input gamma is FLog - Output color space is Rec 709 - Output gamma is Gamma 2.4 All other nodes to grade the clip proceed the node that contains the color space transform. Hope this helps. Don
      Ohio River, Kentucky - Indiana, USA Ohio River, indiana - Kentucky, USA
    • Interesting, and a bit subtle. I also think it'd be better to activate on a half press. But there seems to be good reasoning behind a number of other choices, so I wonder if there's a good reason behind this one and we're just not seeing it. To some degree IS goes on and off like AF does, but this is an exception, isn't it?
    • I couldn't find my manual so downloaded a PDF copy and did some searching.  From p146 of the manual, regarding Shooting Only stabilisation: "Image stabilization enabled only when the shutter button is pressed halfway (focus mode C) or the shutter is released." So it appears that the camera is 'working as intended' and that in AF-S the stabilisation mechanism kicks in only as you release the shutter. I think I would prefer it to activate on a half press, like it does in AF-C.
    • Sometime a short break can help to phrase things so that they do not sound annoying, Well that is the hope anyway, so here goes. Having that meter would be nice as well as having the histogram. But having them or not is a minor consideration in terms of what you are wanting to do because the app does not work with intervalometers. The only way you can get a time lapse sequence using the app is to manually click the shutter button, wait then click it again and so on. Even if the meter were there, you would need extremely fast reflexes to see and react to a lighting change by changing the settings and then going back to clicking the shutter button. Doing that for hours would be a feat indeed. The equipment you mention does this by analyzing several past images and predicting what settings to apply to the next incoming image. Right now the app has the live view which will tell you if an area is over or under exposed, but as far as what you are wanting to do without being able to connect the app to an intervalometer, well …
