About XE4 settings.
I do not use Flickr, so I do not know what their BB code is. All I did was copy the second link you provided, (starting at https: and ending at _k.jpg) and pasted it into the message. After a moment, a message popped up asking if I wanted to paste it as the image or as a plain link. I did this twice, the first time I had it paste in as the image and the second time as a link. Nothing fancy or tricky.
By FrankWeiser · Posted
By JovialLich · Posted
Hi everyone I find why it did that, it was because I shot with the flash at the second curtain.
