Cusom settings issue
Is there a way to save "Exposure/white balance simulation" switch to custom settings? When setting up custom settings bank the parent folder "Screen Setup" is always greyed out...
Funny, just read in the other post " Fuji cameras are known for their custom settings capabilities", or something like that :)
I'd add "...screw ups" to that phrase :) It would be more accurate.
I think you are saying you want to switch between custom settings and change that display setting (as opposed to a setting that affects the recorded image). As far as I know, the display settings persist across all dial positions (PASMC..). The strategy I use is to assign custom settings to modes of using the camera, i.e. landscape, portrait, street, etc. if there are different things I like to do in those modes, I decide where to put modifiers, like face detection, film simulation, etc. You have 3 more choices:  button, the Q menu, My Menu. If you need it instantly (face detection on/off, subject detection) I put it on a button. If I like to be able to see the state because  I change it often, I put it in the Q menu. I only use 8 and it's the things I change the most. MyMenu is where I put the next level of things I change, including most things I change from default so I can verify they are set correctly.
tl;dr; Put it on a button if you change it frequently, or MyMenu.
@brianco, Thank you for the advice. That's what I ended up doing, assigned it to the Fn1 button. The issue is still present in FW ver 4.0.
What couldn't they just save all settings currently in effect to C1, C2, ... and then recall them when the wheel is turned into one of the custom modes position. That's all, just a single menu item "Save current settings", and select C number. Instead they have a whole lot of menus and sub-menus. It looks to me it is overly engineered to the point of being unusable. I bet some junior programmer was working on this part, and the supervisor had no time to check on him/her periodically...
I wish the custom settings saved everything also. The exceptions of what it does not save means I don't use them. Could never find a use case where I knew every setting was how I wanted it except what I want to change if that makes sense.
The advice for using a button and then Q menu for items you need to see the status of is good.
    • HI Rufo, I have changed procedures.  I now use the colors space transform (CST) as my first node.  The CST is set up as follows: - Apply the CST effect to the first node. - Color Space is Rec 2020 - Input gamma is FLog - Output color space is Rec 709 - Output gamma is Gamma 2.4 All other nodes to grade the clip proceed the node that contains the color space transform. Hope this helps. Don
      Ohio River, Kentucky - Indiana, USA Ohio River, indiana - Kentucky, USA
    • Interesting, and a bit subtle. I also think it'd be better to activate on a half press. But there seems to be good reasoning behind a number of other choices, so I wonder if there's a good reason behind this one and we're just not seeing it. To some degree IS goes on and off like AF does, but this is an exception, isn't it?
    • I couldn't find my manual so downloaded a PDF copy and did some searching.  From p146 of the manual, regarding Shooting Only stabilisation: "Image stabilization enabled only when the shutter button is pressed halfway (focus mode C) or the shutter is released." So it appears that the camera is 'working as intended' and that in AF-S the stabilisation mechanism kicks in only as you release the shutter. I think I would prefer it to activate on a half press, like it does in AF-C.
    • Sometime a short break can help to phrase things so that they do not sound annoying, Well that is the hope anyway, so here goes. Having that meter would be nice as well as having the histogram. But having them or not is a minor consideration in terms of what you are wanting to do because the app does not work with intervalometers. The only way you can get a time lapse sequence using the app is to manually click the shutter button, wait then click it again and so on. Even if the meter were there, you would need extremely fast reflexes to see and react to a lighting change by changing the settings and then going back to clicking the shutter button. Doing that for hours would be a feat indeed. The equipment you mention does this by analyzing several past images and predicting what settings to apply to the next incoming image. Right now the app has the live view which will tell you if an area is over or under exposed, but as far as what you are wanting to do without being able to connect the app to an intervalometer, well …
