HELP lens flickering & making clanking sound when turned on
Hi Oliver,Thank you for writing.X-H2S firmware 2.1 was the best. It did not require two selections of record to get the camera to record for more than a few moments--one selection was enough. Version 3.00 and 3.01 has broken this and now requires selecting record twice as did firmware version 2.0.Be careful what you wish for on DJI upgrading the firmware so that it allows of the X-H2S on the RS2. In looking at DJI’s compatibility chart of the X-H2S with RS3 it does not do very much except start/stop record. At least with the RS2’s current firmware, from the Ronin App I can also adjust the X-H2S' shutter speed, aperture, an ISO through RavenEye.Don
If you long press the disp/back button you should see which function is associated with each of the buttons - scroll down and see if Q is associated with Q
It appears that I didn't assign the front command dial to ISO. Problem solved.
By sulley1982 · Posted
im also interested in getting the sigma trio v the fuji f2 primes .i can really afford the new fuji 1.4 . im only a hobby photographer . so i think ill go the cheaper route .i think leaning towards the sigma's over the fuji f2 -
Hi, I would like to use the app for remote view/shooting, but cannot get it to work. I’ve tried deleting the app and reinstalling and can get a bluetooth/wifi connection but am getting an error message when i select “live view shooting” on the app. It says “camera processing - switch to play menu or shooting menu” (see attached). Neither of those worked, however, I don’t know what is meant by “shooting menu” as there are many shooting menus. Please advise of any advice on this topic. thank you Tim
