Cannot preview Images taken on XT5
Leigh
I have the XT3 and just started using an XT5. My normal workflow is to preview my images on my ipad in the Files app before importing to Lightroom. Files from the XT5 only show up as icons with the file number and size data. No thumbnails and no ability to view the images. I tried previewing in Lightroom instead. The same thing happened in preview mode. Icons only and no images. I could import the files into Lightroom and see the images that way, but I have no idea what I'm importing until it opens. As you can imagine, this is not a viable workflow. Anybody besides me experience this? It's the weekend, so I can't reach Fuji support.
https://support.apple.com/en-us/HT213267
Apple has not yet updated their file system(s) to support viewing X-T5 raw files in the Finder / Files app. Some third party apps which rely on Apple’s background processes will not show the files either.
Usually this does not take a terribly long time to get fixed, but it does depend on Apple getting around to doing that. You might drop them a line.
I spoke with Apple support yesterday and they acted like deer in the headlights and eluded it was a Fujifilm issue. Do you suppose Adobe is the same in regards to not being updated to support the XT5 files in Lightroom?
https://helpx.adobe.com/camera-raw/kb/camera-raw-plug-supported-cameras.html
Adobe does say the X-T5 is supported in newer versions of Lightroom, but I do not know if that is only for the desktop versions of LR, Adobe may rely on Apple’s os for the iPad version.
I think you will find large corporations tend to point fingers at each other as to who is at fault, and eventually a fix is sent out. Apple has, in the past, waited to release camera support updates until they release an update that supports a lot of new cameras at the same time.
Edited by jerryy
The XT5 images are supported by Lightroom on the iPad - the only place you will see the blank square is when you are importing from the Photos app which doesn't support the XT5. Once the files are imported into Lightroom from Photos you will see them. Apple takes a long time to support new Fujifilm cameras - X-H2 isn't supported yet either (and of course compressed raws aren't supported from any Fujifilm X series camera).
Greybeard thank you so much for your response. I went back and realized I had not tried uncompressed files in Lightroom. I had tried both in the Apple Files app, but not LR. I tried the uncompressed after your response and all is good. I can see previews!!! THANK YOU!!! You ROCK!!
    • HI Rufo, I have changed procedures.  I now use the colors space transform (CST) as my first node.  The CST is set up as follows: - Apply the CST effect to the first node. - Color Space is Rec 2020 - Input gamma is FLog - Output color space is Rec 709 - Output gamma is Gamma 2.4 All other nodes to grade the clip proceed the node that contains the color space transform. Hope this helps. Don
      Ohio River, Kentucky - Indiana, USA Ohio River, indiana - Kentucky, USA
    • Interesting, and a bit subtle. I also think it'd be better to activate on a half press. But there seems to be good reasoning behind a number of other choices, so I wonder if there's a good reason behind this one and we're just not seeing it. To some degree IS goes on and off like AF does, but this is an exception, isn't it?
    • I couldn't find my manual so downloaded a PDF copy and did some searching.  From p146 of the manual, regarding Shooting Only stabilisation: "Image stabilization enabled only when the shutter button is pressed halfway (focus mode C) or the shutter is released." So it appears that the camera is 'working as intended' and that in AF-S the stabilisation mechanism kicks in only as you release the shutter. I think I would prefer it to activate on a half press, like it does in AF-C.
    • Sometime a short break can help to phrase things so that they do not sound annoying, Well that is the hope anyway, so here goes. Having that meter would be nice as well as having the histogram. But having them or not is a minor consideration in terms of what you are wanting to do because the app does not work with intervalometers. The only way you can get a time lapse sequence using the app is to manually click the shutter button, wait then click it again and so on. Even if the meter were there, you would need extremely fast reflexes to see and react to a lighting change by changing the settings and then going back to clicking the shutter button. Doing that for hours would be a feat indeed. The equipment you mention does this by analyzing several past images and predicting what settings to apply to the next incoming image. Right now the app has the live view which will tell you if an area is over or under exposed, but as far as what you are wanting to do without being able to connect the app to an intervalometer, well …
