Fujifilm 100-400mm OIS
GeorgeVega
Has any 100-400 owners have or had any issues with the OIS?
When in IS Mode 'Continuous" or Shooting Only" the OIS on my 100-400mm will function normally for a while and then suddenly stop working, the only way to get it working again is to turn the camera off for about a minute and then turn it back on and the OIS will start working again, also switching the OIS ON and OFF on the lens does not help, this happens on my X-T3 and now also on my X-T5, its annoying when trying to shoot wildlife handheld and suddenly you have no OIS. Any ideas?
Going on a whale watching cruise on a large sailboat. Is it crazy to expect my XH-1 and even more importantly that my 100-400mm can work well enough against boat movement? This question assumes not sailing in really rough conditions. I know there is no perfect answer, but I don’t want to haul this largish system around for half a day for nothing. Perhaps I should dry dock myself and stick to street photography! 😅
    • I currently have my GFX100s camera in to the Fuji repair shop in Canada but I hear they redirect everything to a central North American one in the US.  (Which might explain part of why there is a delay in getting a diagnostic.). The answer so far is that they want to charge me $400 to do a "more advanced" pixel mapping than is available on the firmware mapping.  If that doesn't work then they recommend a sensor replacement but have not quoted that price yet. I have liked everything about the GFX100s (almost everything) until this started getting worse.  I usually only see it in portrait work when I'm working in more moody, low key setting - which unfortunately is a style I like to work on.  I can see the problem going back to six months after I bought the camera but it was not as strong and I treated it as typical bad pixel mapping.  Except that was only a temporary fix. I'm also reluctant to replace the sensor since the last one barely made it a year.
    • I've got a sensor on a GFX100s that seems to have bad pixels / bright pixels that are not controlled by the pixel mapping in the firmware.  Pixel mapping improves the images temporarily but even after mapping does not completely remove bad pixels.  Although this problem became significantly stronger a couple of weeks after the one year warranty ended I can see them in low key shots at least sas early as six months after purchasing the camera.  Other than I'm disappointed Fujifilm does not seem to consider this a defective sensor but an out of warranty situation with the cost on me.  I find it alarming that the most expensive body I've bought lasted for such a short time - especially after the research I did when I switched to Fujifilm suggested they had strong builds and quality control.  I would really appreciate comments on experiences with other GFX sensor problems becasue at this point I cannot justify spending that much money to fix something that has failed so quickly.  This is night and day difference in my experience with previous cameras and their manufacturers. Thanks,  John
    • I use a 3 Legged Thing L bracket that is not intended for a GFX body and is a generic large bracket they have.  It gives me enough space between the side of the camera body and the bracket that is becomes a handle and I have got used to this will all my bodies.  I get quite a few comments from other photographers seeing me use it since it provides ability to better stabilize in addition to the 90 degree rotation on a tripod. I believe I have the QR11 Universal L-bracket system, but that may have been replaced by a new slightly different shaped model.
    • These help keeping our forum alive
    • Apart from the ridiculous Amazon links here, which do not help, My X-H2 doesn't recognise firmware updates for Body or Lens. Help!
