I've encountered this same problem, also on an X-E4. I hadn't had any problems with the camera, I just wanted to test the procedure. Some points: - I use a PC running Windows - The version of Acquire is the latest. - I also own an X-S10 and backup and restore worked fine with that, and I'm using the same cable, etc.
Beauty, functionality, originality, beautiful images and optics, optics, optics. What's not to like?
This is just a guess, but the specifications for that monitor say it only supports 8-bit bit-depth. Most of the video outputs for the X-T3 are set to support 10-bit bit-depth. Try using the H.264 codecs, with the same frame rates, etc. and see if you get an image. edit: https://fujifilm-dsc.com/en/manual/x-t3/technical_notes/spec/index.html H.264: SD card, 4∶2∶0, 8-bit/HDMI output, 4∶2∶2, 10-bit
Last time I powered on the camera, I noticed that when in aperture priority the display of shutter speed disappears. Same if I go to speed priority, the F display disappears. Until last time I used the camera everything was fine. They now both only appear when in manual. I went through every possible menu but could not solve the problem. any help? Thank you.
By john giskes · Posted
Hi, I bought a AndyCine A6II HDMI camera monitor. But the display can't be connected to my X-T3. I had the same problem with an earlier bought Viltrox DC-550 pro camera monitor. If I put my camera to a HDMI port of my computer monitor it shows the picture from the camera. This monitor is able to display a 4K 25frames, and below, videosignal. I had a Viltrox lens attached to my camera, later I switched it for a Fujifilm 18-55mm. Any idea what could be wrong?Welcome, dear visitor! As registered member you'd see an image here…
