Lost Eyecup / Eye Piece X-Pro 2
Hey guys, lost my eyecup as well...
Well actually, I found it split in half in my bag.
My theory is that the eyecup is rubbing on my bag and got damaged this way.
I wonder what is the turn around for Fuji? I saw online some people received the part other had to send their camera away.
I have an authorize service center near my house. I wonder if I can just show up and have them fix the issue?
I'm pretty sure this is a manufacturing defect. It happened to my camera and Fujifilm's service center in Singapore replaced it without charge, within a day.  When I went to pick up the camera, there was another gentleman there who had the same issue and he had his replaced by a service center in Japan while he was traveling there.
A part like this which is not supposed to be removable, shouldn't come off so easily so often. My cameras are used for work so they do take a bit of a beating, but I expect a 'pro' camera to be somewhat durable. Hence my thinking that this is a manufacturing defect and should be on Fuji to replace. Happy they did so in my case!
Have just returned from 9 days in Norway... without my replacement eye cup :( Fortunately, it stayed on whilst I was in the very wet Bergen area and I remember thinking that it was doing a good job. Alas, somewhere in Oslo it had fallen off, but luckily it was sunny all week. I now regret not gluing it on.
again, despite the fact that it is technically possible to glue the part on (if not broken in two as few people have reported), this would:
1) Void the guarantee
2) You can never be sure that the camera will still be as weather resistant as Fuji made the camera to be.
Hence the need to send the camera to its maker and have it fixed by them, hopefully in a more permanent way.
This is probably a design fault which should have been detected and solved BEFORE the cameras came out but unfortunately, due to the pressure to introduce cameras as soon as possible and limiting the Beta tests to a bare minimum, this appears not to have been the case.
I hope that the X-T2, which underwent and undergoes similar pressure to an early introduction won’t reveal similar flaws in one of more of its parts.
Almost anyone whom I know has bought the X Pro 2 has had to deal with this problem, which to me means that also a fair number of the beta testers must have had the same, but apparently Fuji is subscribing to “ risk making a mistake now and say sorry later, if that is the case”.
Trouble is the word "hopefully" - I can't see how they can re-engineer what is simply a push on component. Fuji put on the original, it fell off. I put on the replacement, it fell off. So, I conclude it is a design fault. Even when attached, it barely does the job and poorly serves us glasses wearers. I'm a little surprised that the army of professional beta testers didn't insist on changes.
I am sure that, by now, they have been swept by such a wave of complaints about this that they will come up with a permanent solution.
If you repair this yourself, don’t complain if, the moment something else will go wrong, that they say, “ well it is because you repaired it yourself’.
On April 23, 2016, I posted the following comment concerning a replacement eye-cup.  The one I made is still working fine and is firmly in place.  Here is what I said:
I wear glasses and with my XPro 2 had problems with blocking out side light around the original eye piece.  I purchased a Nikon eye cup DK-19 for $1.50 (free postage) on Ebay which fits perfectly around the outer circumference of the Fuji rubber eyepiece.  I first masked off around the Fuji eyepiece with masking tape and twice tried to attach the Nikon eye cup with Elmer's rubber cement.  Although I followed the label instructions for a "stronger bond", this failed twice.  I then used with complete success Permatex Adhesive Sealant Clear RTV Silicone (80050).  DAP makes a like product, both being widely available.  Without my glasses this now works perfectly to block out side light, with the glasses on it is better than before.  I also find that in my case I can slightly adjust the diopter adjustment to provide sharp vision in the EVF without wearing my glasses.  It is adequate on the LCD.  I was at first concerned that the added Nikon eye cup would protrude back too much but it doesn't.
Here is someone else who used a DK-19:   https://www.dpreview.com/forums/post/57599694
Having lost my 2nd eye-cup, I returned my XPro2 for repair. This was a very fast and simple process:
  1. Filled in a support request form online
  2. Fuji posted me the pre-paid return packaging
  3. Posted camera to Fuji
  4. Camera returned to me 5 days later
On the plus side, the camera has been thoroughly cleaned, like new!
On the downside, they performed a factory reset losing all of my customisations... I also had to learn how to use my X-T1 buttons again which was remarkably frustrating but I still got good images!
Phoned Fuji in New Jersey directly and spoke to Steve Skolsky.  Very helpful explaining what has happened and how this is probably the biggest design flaw on the X-Pro2.  I dislike the fact I can see the innards of the electronics without the eye piece.  He sent me an email to respond with my contact information and he sent out a new piece.  I may just have to use an additional adhesive to make sure it doesn't get pulled out when I pull the camera from the bag.  No longer need to send out for service and be without a camera.
I had the same experience but I can't get my new rubber eyecup to fit and stay. Did you have any issues and how did you get it to work? Thanks! Terry
Sugru.
I posted a thread on the other Fuji X forum on this a short while ago. One of the (many!) comments referenced a blogger who is collecting a database of X Pro2 customers dissatisfied with Fuji's unacceptable response to this small but significant design flaw. I'd encourage everyone to add their names to the list to try to get Fuji to bring out a more robust fix.
I live about 25 miles from Fuji in Edison NJ. I use my gear for work (and play) and I don't like a consumer experience when I need help.
I have found that Fuji repair in Edison goes out of their way to make life easier when I do have a problem. Do a little research and find
out the right person to hit up with an email. You just might get them to send the eyepiece to you. Especially if you work with your camera.
My XT1 grip had the rubber material sliding off. I was using it a lot this summer and I guess the heat and sweat caused it to start peeling away
from the body. After a while it was a real pain in the butt so I dropped it at Fuji. I wasn't in a rush and so waited for the estimate to be
mailed to me. How much could it cost to put some glue on the camera body? When I got the 149.00 estimate I drove back down to
Fuji and asked to speak with a supervisor. I got the guy in charge of the repair department. I explained that I didn't mind paying for the
work but 149.00 I thought was a bit excessive. The guy knew what gear I owned before he came out to talk to me, and we had a nice discussion about the X cameras. He then said he would do the repair free and throw in a cleaning and calibration. I thought that was very gracious and probably a good business decision based on how much Fuji gear I own.
Good luck with the eyepiece, I'm sure I'm right behind you with that thing.
  • 5 months later...
  • 11 months later...
Loading...
 Share
    • By Fujiuser21
      Hey guys,
      I recently purchased a used fujifilm x pro 2 which looks really in great condition. There are only 1-2 really small and not really noticeable scratches.
      So the problem I have is actually that the camera sometimes doesn't turn on. I switch it off between taking pictures while walking and sometimes when I try to turn it back on it doesn't light up. I've read here and there that a few other people also encountered this issue but didn't really update us on it.
      So my question is if someone has dealt with this and what could be a solution to it.
      If there's no solution I actually really like my fuji x pro 2 and would be interested if the issue becomes worse with time or it stays quite the same.
      Thanks in advance guys!
    • By Creativestubble
      Hi all,
      First post here.
      Hope some Fuji users can help - any questions answered will be helpful - thanks in advance.
      I currently shoot with a Nikon D90 and 50mm prime for street photography. I really want to switch to Fuji. I went to check out the Fuji range and was initially considering the X-T20, X-T2, X-Pro 2. (All with 35mm F2)
      After putting the EVF to my eyes for a minute I felt kind of sea sick, Ive never looked through an EVF before. So I am left with OVF as the only option. This leaves the X100F and X-Pro 2 as my only options.
      1) I wear glasses - and found the viewfinder very small on the X-Pro 2, the OVF is also quite unusual to use. Does anyone else find it difficult to use (glasses wearers?) Is parallax an issue here?
      2) I see the X100F OVF seems much bigger and clearer, do users find this?
      3) Im concerned to buy an X100F as the fixed lens may be restrictive - I know it has crop modes, does the OVF adjust to the crop mode selected - or only the frame lines?
      4) Should I wait for X-Pro 3 before buying X-Pro 2? (either because X-Pro 2 prices may drop, or because they may improve the OVF on X-Pro 3?)
      5) I know they are different cameras - but would you get an X-Pro 2 over an X100F? I like the X-Pro 2 more aesthetically (doesn't mean its better in practice)
      Thanks,
      Darren
    • By Nanc2019
      Does anyone know if the eyepiece can be replaced? Or any tips how to fix this?
      I recently bought an x-t30 and the rubber or skin of the viewfinder just peeled off. The camera has been barely used since I got  busy with work.
      Any advice would be much appreciated.
      Thank you!
    • By Guzzi Jim
      Taken with my X-pro 2 with manual nikkor 105mm F2.5
    • By petergabriel
      I get conflicting info online. I am trying to figure out whether the hole for the EVF/OVF is bigger on the xpro2 vs xpro1. Some say 16mm vs 14mm. Which is it?
      Also, some claim the magnification is larger on the xpro2 vs xpro1, and then some spec lists claim that it is actually smaller. Which is it?
      My only local camera store closed last year so I have no way of finding out for my self unless I order online.
      Thanks.
    • I must have activated the wrong setting because now when I switch to the OVF the white windows stays for a second and then completely disappears. Any idea how to get it back? Thank you all so much. 🙂
    • No thunder stolen. If you read to the end of my article you'll see (in the section "Resources") I have a link for Simon Weir's site. I also have two other links on there with various IR tests. My article is only Fuji-centric because that is my system of choice though I've done a ton of IR work with Sony FF as well. I consider the sites for which I provide links to be complementary and I wish there were more sites out there evaluating for infrared. Although I test for infrared quite thoroughly I can only afford so many lenses. The eight Fuji mount lenses shown in my article I bought myself. In fact, same with the Sony and Micro 4/3 with the exception of the two Sony APS-C zooms that were rented. Also when I get new lenses, I'll update the article on my blog. I can't update the PetaPixel one as they just republished what was on my blog at the time. I have recently shot with the Voigtlander Nokton 35mm f1.2 Fuji-X and 7Artisans 35mm f0.95 Fuji-X. After trying 2 samples of the Voigtlander I returned them both but mainly for their strange and unacceptable (for my work) performance with resolution. Regarding IR, the Voiglander is free of hotspots from 1.2 through about f3.5. I'm impressed with the 7Artisans overall but it only works for IR at wider apertures (f0.95 through about f2.8.) Then again that's why you buy an f/0.95 lens. Thanks for the feedback. Happy shooting! Joel
    • Yes I don’t blame you. I’ll always have some Fujifilm gear. But if they don’t upgrade their gear in the next 3 months I’m going to go back to Canon for a lot of my work. I really love Fujifilm for all the right reasons but it’s faults are getting in the way of my work at this point.
    • You're welcome. I still use my X-Pro2 for personal work every now and then, but I replaced the X-H1 (and the rest of the Fuji-kit) with a Z7II-based kit and I'm very satisfied with that move.
    • That’s a lot of great info. I’m gonna explore those options. I don’t really wanna get an XT4 at this point. (Come on X-H2!) Thanks!
