Connection Mode problems
gdmmd
I cannot change my camera's Connection Mode from X Webcam.
It is not highlighted and is passed on over when I move the cursor down the connections settings.
Need help to change this. Note that I have tried deleting X Webcam from my Mac to no avail.
