x-pro 2: What image quality settings do you use?
No grain
DR Auto
Highlight Tone: 0
Shadow Tone: -2
Color: 0
Sharpness: 0
Noise Reduction: -4
Film Simulation:  Classic Chrome
I have found I like the look of this a lot.  With the -2 on shadow tones the blacks don't seem to get crushed.  This is what I start with in LR.
I shoot raw, where most of these settings have no effect. That way I have more control over the image quality in post, and I start out with a higher quality file.
I shoot raw as well. Typically I have slot 1 shooting RAWs and slot 2 shooting jpgs. The settings will still effect in camera RAWs if you have it set on a film simulation. It strips it once you dump it into Lightroom.
I use 'professional'
Oh ok, thanks.
