Playback issue
Ulysses1922
Hi there!
A stupid question, I’m sure, but when I press the playback button to review the shot on the LCD screen, the playback image has also, just now, started appearing in the EVF display as well. I have never seen this before with the playback being solely on the LCD. Is there a setting I am missing somewhere?
Many thanks for your help.
Ben
