"PREVIEW DEPTH OF FIELD" function - what's the point? It's ALWAYS previewing.
Why is there a "PREVIEW DEPTH OF FIELD" function? I am ALWAYS seeing the effect of the DoF. As I turn the aperture ring I see more or less blur on things not at the focused distance. In fact, if I turn the camera round, I also see the blades of the aperture stop move in and out as I turn the ring.
What does the function change? Seems like nothing, as far as I have been able to notice.
If it matters, this is on an X-T4 with a Fuji 35 f/1.4 lens.
Thanks!
In aperture priority - set the lens wide open - choose a scene with objects at different distances - now press the button you have assigned to "PREVIEW DEPTH OF FIELD" and the effect should be obvious.
(I checked it with X-S10 but X-T4 should be much the same - its not something I ever use as half press will do the same and also focus on the subject)
Edited by Greybeard
 Share
    • Thanks @cpX – from those threads I draw the conclusion that there is some aspect of OIS that you can't turn off. It's a shame that the link provided in the page that your fourth link leads to, for Fuji discussing this in a support article, is broken.
    • That will probably be the drive of the Powerzoom. https://www.dpreview.com/forums/thread/4567793 https://www.fujix-forum.com/threads/fuji-xt4-body-16-80mm-lens-sound-problem.108054/ https://www.dpreview.com/forums/thread/4558158 https://www.dpreview.com/forums/thread/4501861
    • On my X-T30, with the 16-80mm lens, I hear a constant whirring from the lens while the camera is turned on. I thought this must be the IS, so to conserve battery I went to the menu and set IS to "Shooting+motion", but there was no difference. Then I tried setting IS to "Off" – still no difference, there is still a constant whirring from the lens. I turned the camera off, took the lens off, put it back and turned the camera back on – no difference. What is going on?
      Brackwede ● NRW ● Germany.
    • https://digitalcamera-support-en.fujifilm.com/digitalcameraengpcdetail?aid=000005639 Scroll down to the X-T30 section. You should be okay as long as it is 5v 1.5a and uses the standard USB-C cable.
