Let’s Drop The RUMOR-BOMB: Fujifilm is forging a MEDIUM FORMAT CAMERA (Source Right in Past)
Hello. Thankyou,now Is all more clear: I have take some time in you link. Let tell you.i was totaly forget this machine have "compress picture option" and not Only "compress lossless" anyway not change the experiment. RAW and this last two format look like same result about Number of recording picture. Can tell alll results in this: in raw you can make 17 pictures for second.Is wrong.Is about One single Press and wait buffer. Full 30/20/10/8 not change. After 17 Need Press again. You not can Press before "redgreen light recording Is on" With preshot you can have 25 are more 7 pictures The story change Only in jpg shot only. In jpg at 30 you have 30 picture but redgreen light off very Fast so you can shot very quicly. At 20 shot Is about start look like infinite shot. 150 picture +- So the best performance are this last One I want take a shot about Italy cyclet Just for passion. I think i Will use this last setting.
By FrankWeiser · Posted
By JovialLich · Posted
