X-Pro2 Half Cases
    • Does it use wi-fi when you are not specifically attempting to transfer files?
    • Hello dear Fujifolks - I come from 54 years of shooting Nikon cameras, and this is my first Fujifilm experience as I've just sold my Nikon D7200 in exchange for a tiny but endearing X-T20. Very pleased with it as it's so lightweight, but very well built. But takes some getting used to the menus and settings after Nikon's DSLR functional simplicity ! I'm working on it though and slowly coming to terms with the new system. My question for now is this: is there any way to turn OFF the wifi antenna in the camera ? I'm particularly wifi signal sensitive and have no intention of using that function as I do all my editing and printing on my PC. I've checked the wifi menu options but cannot find a simple wifi ON-OFF selector. Thanks for your help and I'll be back with more Q's when needed. Blessings to you all...
