Possible problem with 16-80 f4. Can any owners help?
BobJ
My 16-80 has an annoying characteristic. The extending part of the lens barrel wobbles. When fully extended to the 80mm position the front of the lens has approx. 1.5 to 2mm play. This doesn't sound much but if examined in the viewfinder it is disconcerting to say the least. Apart from possible effect on the resolution I am worried, that if out in high winds, the lens will wobble about during the exposure, especially if a lens hood is fitted. My 70-300, despite having a much longer extension doesn't suffer with this problem.
My question is, is this the same on other examples or do I have a faulty lens?
P.S. The 16-80 needs a zoom lock. When the camera is carried on a strap it 'trombones' every time. The 70-300 has one but doesn't seem to need it!
I talked to the Fuji guy who was examining cameras for free at the show and he said that it is within spec. Their example was much tighter though! I know from experience that, although Fuji repair have been very good with obvious faults, that it will probably be a waste of money to send it in. I have bought a third party lens hood (Haoge lh-x18). This is metal, has a completely different design, and is heavier than the Fuji version. I am more confident that the lens will stay stable in high winds with this hood on.
    • I currently have my GFX100s camera in to the Fuji repair shop in Canada but I hear they redirect everything to a central North American one in the US.  (Which might explain part of why there is a delay in getting a diagnostic.). The answer so far is that they want to charge me $400 to do a "more advanced" pixel mapping than is available on the firmware mapping.  If that doesn't work then they recommend a sensor replacement but have not quoted that price yet. I have liked everything about the GFX100s (almost everything) until this started getting worse.  I usually only see it in portrait work when I'm working in more moody, low key setting - which unfortunately is a style I like to work on.  I can see the problem going back to six months after I bought the camera but it was not as strong and I treated it as typical bad pixel mapping.  Except that was only a temporary fix. I'm also reluctant to replace the sensor since the last one barely made it a year.
    • I've got a sensor on a GFX100s that seems to have bad pixels / bright pixels that are not controlled by the pixel mapping in the firmware.  Pixel mapping improves the images temporarily but even after mapping does not completely remove bad pixels.  Although this problem became significantly stronger a couple of weeks after the one year warranty ended I can see them in low key shots at least sas early as six months after purchasing the camera.  Other than I'm disappointed Fujifilm does not seem to consider this a defective sensor but an out of warranty situation with the cost on me.  I find it alarming that the most expensive body I've bought lasted for such a short time - especially after the research I did when I switched to Fujifilm suggested they had strong builds and quality control.  I would really appreciate comments on experiences with other GFX sensor problems becasue at this point I cannot justify spending that much money to fix something that has failed so quickly.  This is night and day difference in my experience with previous cameras and their manufacturers. Thanks,  John
    • I use a 3 Legged Thing L bracket that is not intended for a GFX body and is a generic large bracket they have.  It gives me enough space between the side of the camera body and the bracket that is becomes a handle and I have got used to this will all my bodies.  I get quite a few comments from other photographers seeing me use it since it provides ability to better stabilize in addition to the 90 degree rotation on a tripod. I believe I have the QR11 Universal L-bracket system, but that may have been replaced by a new slightly different shaped model.
    • These help keeping our forum alive
    • Apart from the ridiculous Amazon links here, which do not help, My X-H2 doesn't recognise firmware updates for Body or Lens. Help!
