X-S10 built-in flash always Off
Zababo
Hey, I can’t turn the  built-in flash on!
Even opening it before turning on the camera, the mode I use (A,S with a speed < 1/180, M ..) …
And, in the flash menu, I only have access to “red eyes removal” and “TTL-lock mode”.
What could be my wrong parameter?
Thanks
Thanks CatsAreGods,
My shutter is on Mechanical only. I tried to open the flash after turning on the camera: same thing.
I think the best is to reset the camera and to program the camera anew.
Is it possible it’s in relation with firmware upgrade to 2.4 or simply a coincidence?
When I wrote this topic, I’ve done a total reset, but, then, the flash menu was available only once and then, as I’ve set up my choices, disappears anew.
I did the same and then , in auto mode, the flash accepted to fire.
As said Greybeard, it’s the proof it’s a firmware incompatibility which my selected choices.
Thanks.
