XT3 freeze, screen unresponsive 2022
joojhom
My XT3 froze while i was changing wb in the menu after a day shooting in direct sunlight and hot weather. SD card is Lexar 1066x 120mb/s write. No overheating warning popped up or any form of high temp warning, but camera was very warm. The screen was unresponsive and would not turn off after i had turned it off. I was in the car with air conditioning when this happened so it was cooling down. The shutter still worked when i pressed it but no photo was written to the card.
I can't  say that the sd card is the cause in your case but I had intermittent freezes which turned out to be a faulty Lexar card. Note that you will have to replace both cards to try it  as one card will hang both. I don't buy Lexar cards any more.
it doesnt seem to be the fault of an sd card thoughy as i was in the settings changing white balance and no orange transfer light was on, the screen just froze and wont turn off
    • Hello dear Fujifolks - I come from 54 years of shooting Nikon cameras, and this is my first Fujifilm experience as I've just sold my Nikon D7200 in exchange for a tiny but endearing X-T20. Very pleased with it as it's so lightweight, but very well built. But takes some getting used to the menus and settings after Nikon's DSLR functional simplicity ! I'm working on it though and slowly coming to terms with the new system. My question for now is this: is there any way to turn OFF the wifi antenna in the camera ? I'm particularly wifi signal sensitive and have no intention of using that function as I do all my editing and printing on my PC. I've checked the wifi menu options but cannot find a simple wifi ON-OFF selector. Thanks for your help and I'll be back with more Q's when needed. Blessings to you all...
