Change film simulation in jpg (no RAW available)
There are lenses without an aperture ring.
In aperture priority - set the lens wide open - choose a scene with objects at different distances - now press the button you have assigned to "PREVIEW DEPTH OF FIELD" and the effect should be obvious. (I checked it with X-S10 but X-T4 should be much the same - its not something I ever use as half press will do the same and also focus on the subject)
By Astigmatism · Posted
Why is there a "PREVIEW DEPTH OF FIELD" function? I am ALWAYS seeing the effect of the DoF. As I turn the aperture ring I see more or less blur on things not at the focused distance. In fact, if I turn the camera round, I also see the blades of the aperture stop move in and out as I turn the ring. What does the function change? Seems like nothing, as far as I have been able to notice. If it matters, this is on an X-T4 with a Fuji 35 f/1.4 lens. Thanks! -
Interesting that two actual owners of the X-H2S should have similar thoughts on its IQ, (and the plethora of improvements in the camera itself), and have been able to physically compare it to the X-T4, side by side. Interestingly the OP, whilst commenting on Ken's review, stated that he had, "already drawn pretty much the same conclusion about it". If you own one and an X-T4 then your conclusion is valid. If not then....... As I alluded to earlier, I have never seen any photo examples to confirm Ken's points and until then I will treat his reviews as I have always done, which is one of idle curiosity.
So if it is no better or worse than the X-T3 or X-T4, then why didn’t he call the image quality in those cameras muddy? Because he’s lying.
