Viewing
Sisyphus
Hi
First time posting on here, I own the XT2 and XH1 when viewing images the XT2 images seem to be better magnified than on the XH1 also, It would appear the XH1 under exposes by one stop, whilst the latter means I have to expose 1 stop over is there anyway to get the XH1 to magnify the image more. Oh this is after pressing the rear command dial to magnify the image.
It is true the magnifications are different.
X-H1 specs: Magnification: 0.75x with 50mm lens (35mm equivalent) at infinity and diopter set to -1.0m-1
X-T2 specs: Magnification: 0.77x with 50mm lens (35mm equivalent) at infinity and diopter set to -1.0m-1
There are gadgets called viewfinder magnifiers that are supposed to do as their name suggests, magnify the image in the viewfinder, similarly for the lcd monitor. Check with your favorite local camera store or online store or use a search engine to get an idea of what is involved in using them.
https://fujifilm-x.com/global/products/cameras/x-h1/specifications/
https://fujifilm-dsc.com/en/manual/x-t2/technical_notes/spec/index.html
