Focus issues
botty1963
Hi all, took around 500 photos last week, and when I loaded them on the PC I noticed that around 80 or so had patches of the photos that were blurred. I don't believe it is anything to do with DOF based on the selected aperture, as you can see that in some of the examples there are both blurred and sharp areas in the same plane. I also know where in each I focused, using spot and back button, so I know for example that the one with the boat in it, I focused on the boat but that is out of focus. I used an X-T4 with the 16-80 and had both IBIS/OIS on.  In the one with the white building, I focused on that building but it is out of focus but with other areas that are in focus. Any ideas?
You can find examples here
    • I do not use Flickr, so I do not know what their BB code is. All I did was copy the second link you provided, (starting at https: and ending at  _k.jpg — leave off the [img] and [/img] tags) and pasted it into the message. After a moment, a message popped up asking if I wanted to paste it as the image or as a plain link. I did this twice, the first time I had it paste in as the image and the second time as a link. Nothing fancy or tricky.
    • So do I just copy the BB code from flickr and paste it anywhere on the page like other forums or is there some other trick I need to perform to get it to post?
