X-Trans III: The waxy skin is gone
Beauty, functionality, originality, beautiful images and optics, optics, optics. What's not to like?
This is just a guess, but the specifications for that monitor say it only supports 8-bit bit-depth. Most of the video outputs for the X-T3 are set to support 10-bit bit-depth. Try using the H.264 codecs, with the same frame rates, etc. and see if you get an image. edit: https://fujifilm-dsc.com/en/manual/x-t3/technical_notes/spec/index.html H.264: SD card, 4∶2∶0, 8-bit/HDMI output, 4∶2∶2, 10-bit
Last time I powered on the camera, I noticed that when in aperture priority the display of shutter speed disappears. Same if I go to speed priority, the F display disappears. Until last time I used the camera everything was fine. They now both only appear when in manual. I went through every possible menu but could not solve the problem. any help? Thank you.
By john giskes · Posted
Hi, I bought a AndyCine A6II HDMI camera monitor. But the display can't be connected to my X-T3. I had the same problem with an earlier bought Viltrox DC-550 pro camera monitor. If I put my camera to a HDMI port of my computer monitor it shows the picture from the camera. This monitor is able to display a 4K 25frames, and below, videosignal. I had a Viltrox lens attached to my camera, later I switched it for a Fujifilm 18-55mm. Any idea what could be wrong?Welcome, dear visitor! As registered member you'd see an image here…
