Focusing and flickering
Sany
Background: I am on back button focus mode.
This is more evident in high dynamic range scenes. When I try to focus on one of the points - once in the lit up area object or on the object in the darker zone. When I press my back button to focus, for a fraction of second the bright area in the scene stutters / and kind of over exposing action (when i press the focus button) and when I try to focus on the shade area - the focus flickers for a while hunting focus, but it does the same action of flickering during this. (My back button 'AF ON button' is set to lock both focus and exposure).
Just wondering why this happens - why should it do that stutter. Sometimes, highlight area flickers as though trying to let us know that it over exposed (but the histogram does not indicate any clipping).
Are you getting the problem when shooting in daylight or in artificial light, or both?
With certain artificial lighting, particularly LED office type panel lighting, you can get banding and flickering because of the frequency of the lights. The only way to stop this appearing in your photographs is to use a slower shutter speed, 1/100th or slower.
I noticed mainly outdoor - also i am not sure, I explained it properly. Let me take a small video and share it here.
  • 10 months later...
    • I couldn't find my manual so downloaded a PDF copy and did some searching.  From p146 of the manual, regarding Shooting Only stabilisation: "Image stabilization enabled only when the shutter button is pressed halfway (focus mode C) or the shutter is released." So it appears that the camera is 'working as intended' and that in AF-S the stabilisation mechanism kicks in only as you release the shutter. I think I would prefer it to activate on a half press, like it does in AF-C.
    • Sometime a short break can help to phrase things so that they do not sound annoying, Well that is the hope anyway, so here goes. Having that meter would be nice as well as having the histogram. But having them or not is a minor consideration in terms of what you are wanting to do because the app does not work with intervalometers. The only way you can get a time lapse sequence using the app is to manually click the shutter button, wait then click it again and so on. Even if the meter were there, you would need extremely fast reflexes to see and react to a lighting change by changing the settings and then going back to clicking the shutter button. Doing that for hours would be a feat indeed. The equipment you mention does this by analyzing several past images and predicting what settings to apply to the next incoming image. Right now the app has the live view which will tell you if an area is over or under exposed, but as far as what you are wanting to do without being able to connect the app to an intervalometer, well …
    • I want to check with you guys on how image stabilisation is meant to work on the XT4 and whether I might have an issue. I was out with the camera yesterday with the 80mm macro lens, which has OIS, and the 1.4 Teleconverter and did some tests to see how good the stabilisation was performing by pointing at random objects/general landscape.  On the lens I had the OIS switch turned on and I selected the stabilisation to be always on in the menu option and was suitably impressed with how much camera shake was reduced.  However, when I went in the menu and selected Shooting Only for stabilisation I noticed something odd.  My understanding with this mode is that when you half press the shutter release the OIS is meant to turn on and stabilise the image just before completing the shot.  With the focus switch set to Continuous AF this is exactly what happened - shaky image, half press, stable image.  But, if the focus selector switch is set to Single AF I half press the release and I get no stabilisation.  The focus locks and the exposure locks but the image is still shaky in the viewfinder. I swapped out the lens for my 16-80mm kit lens and this performs exactly the same - no image stabilisation with Single AF selected, so it appears to be something to do with the body and not the lens. Is this normal?  I would be surprised if stabilisation only kick in when you fully press the shutter release because some shots are taken with tiny fractions of a second of exposure and the mechanism will still need a finite time to engage.
    • Thats an interesting question - there appear to be two different remote access interfaces to the camera : Bluetooth/Wi-Fi and USB - the USB interface does have a way of accessing a shutter count - I haven't seen any report that its available via Bluetooth/WiFi.
    • Jerry. We're really travelling in circles here (please refer to my original post). I know what tethering is and how to use it. I use the TL Plus View to trigger a Zeapon system for Time Lapse and the two together work perfectly fine. However, it would be nice to work occasionally without this rig and simply use the Fuji app. The workaround you're describing is unworkable for any serious Day to Night timelapse as, apart from anything else (such as camera touching and therefore unwanted movement) you are constantly looking in the rear view mirror as to what it is you're metering, not to mention that the space between intervals would have to be unusably long. (sigh) All Im asking is that the app displays the exposure when using ANY intervalometer. There may be no serious workaround, but I thank you for your thoughts.
