Which Fuji X cameras do you use?
FX Admin
816 members have voted
  1. 1. Which Fuji X cameras do you use?
    • Fuji X-Pro1
      147
    • Fuji X-Pro2
      96
    • Fuji X-T1
      411
    • Fuji X-T10
      110
    • Fuji X-E1
      105
    • Fuji X-E2
      179
    • Fuji X-E2s
      14
    • Fuji X-A1
      17
    • Fuji X-A2
      3
    • Fuji X-M1
      32
    • Fuji X100
      49
    • Fuji X100s
      87
    • Fuji X100t
      105
    • Fuji X70
      12
    • Fuji X10 / X20 / X30
      60
    • Fuji X-S1
      15
    • Fuji XF1
      7
    • Fuji XQ1/XQ2
      10
This poll is closed to new votes
I had to send a used XT1 back to B&H due to condition but I liked it a lot otherwise.  But I have a new XP1 body with a used 35 f/2 and 18-55 and am loving using them.  Mostly a Nikon DSLR shooter but the XP1 is changing that.  I will likely get an XT1 body when the start dropping in price like the XP1 did.
Bonsoir,
The poll seems to be closed, but fwiw I use XT 1 (+ 18-55 and 14) + X100, the latter being my introduction to Fuji and, despite its idiosyncrasies, is great for walking out and about light. I also like the discipline of a fixed focal length.
Jeremy
X-E2s, X-Pro2.
When I dumped my Sony gear to move to Fujifilm, I kept my RX100m3, a very capable -- though typically soulless -- genuinely pocketable "scout cam". I've never held or even seen an X-70, so it's possible I might trade for that or its successor at some point. I think it's too big, but I don't know.
Hello, X Pro 1 with 18 to 55 on front & X E2s with a 100 to 400 + 2x converter. Also have primes 18, 27, 35 60 for occasional use and a X A1 with the XC Zoom Lens which is redundant now. Next Safari will take the XE2s & zoom and the 27mm - but will not look to be changing lens in the field. And this all came from the XS1 which is still in use in the family.
