Fuji xt4 really can record 10bit ! Maybe Lie..
Nikolas
Recently check with Exiftool(terminal) the video information of my last shoot and i found out bit depth say 24 .. this mean 8 bit pre channel , I'am wrong ?  . I shoot in 1080p H265 10 bit . Also video megapixel is very low . Someone has encountered the same issue?
On 4/22/2022 at 5:31 AM, Nikolas said:
Jerryy suggest to convert my video with ffmpeg before import in finalcut pro x?
No, for most things you can leave it as ten bit video, but if you need to convert it for a device that only supports eight bit video you can convert it easily. Usually you would only convert it after all of the editing is done and then double check that to make sure nothing went awry.
You can rest assured that it looks like your X-T4 is recording ten bit video.
Edited by jerryy
