View finder - good. Final image - bad
I'm new to my X-T4, but battling with something that happened to me.
Taking a passport photo for a child, in the viewfinder, the image looked great. Snapped the photo. But when I 'play' to view it - the photo was extremely dark. I thought, what you see in the view finder - is what you'll get. I'm mistaken I guess. Is this normal for a novice? I fixed it by going fully auto - as I was unable to work out why that happened. And Auto gave me good exposure.
  • 1 year later...
It's quite puzzling to see such discrepancies between the viewfinder and the final image. Factors like exposure, white balance, or even some specific camera settings could be causing this issue. Have you tried resetting your camera to its factory settings or updating its firmware? That might be a good starting point.
On another note, when talking about images and requirements, I recently came across an online platform that helps users understand specific image requirements for various documents across different countries. This might be a bit off-topic, but for anyone who ever struggles with getting the right photo for passports or visas, it's a lifesaver.
Back to your issue, I hope you get it sorted soon! It can be quite frustrating to not get the results you see in the viewfinder.
Edited by filonina
    • Cedar Waxwing, Oregon. X-H2s, Fuji 150-600+1.4TC.
    • Have you checked the settings for jpeg? I found the camera was slow between shots. On the advice of others in this forum I turned 'clarity' tp zero and that makes it much faster. Other jpeg settings on that menu might also make it slow. Lens corrections for instance. I have them at zero because I shoot RAW. Paul
    • No, I was not joking. Reread her post, the first sentence is “The focus mode selector button on the front of the camera has  me baffled.” which is what I explained in my answer: the focus mode selector button. My CSM explanation is essentially the standard approach Fujifilm has taken for some time. Explaining the frame rate differences as I did to someone brand new to the camera seems an easier approach to understanding than saying it is 20fps vs 7fps. Not to mention, the following is how Fujifilm describes it: “Continuous AF: Focus is continually adjusted to reflect changes in the distance to the subject while the shutter button is pressed halfway. Use for subjects that are in motion”  https://fujifilm-dsc.com/en/manual/x-t5/taking_photo/autofocus/  You have to go to page 166 of the manual to get to a very brief explanation of CH vs CL without any context. High speed capture vs slower speed capture seems appropriate to explain so that someone that had been given the impression the top dials are needed for the csm button would realize how they work. I think it is better than saying put the csm button on S the top dial on CH and mash the shutter button — there is no example of when to use that or why. The X-T5 is a wonderful tool, but sometimes examples, humorous or otherwise, help new users understand it better when the manual does not help or when people tell new users to just leave it alone.
    • The burst speed of the shutter is set by the CL and CH control on top of the camera, it is unrelated to the focus mode setting on the S C M control. The focus speed is not related to the burst speed setting. You might have been joking, but your post adds confusion.
    • This switch is for your lens’ auto-focusing. ”C” tells the body to use continuous focusing, either CL (low speed -  for slow moving puppies, kittens or kids) CH (high speed - for faster moving puppies, kittens or kids or anything that.moves quickly or frenetically). CH or CL is set using the top dial settings. The subject keeps moving and it may be tricky to keep trying to focus to get the photo using the standard compose / focus/ take the photo technique. ”S” is for single shot focusing, point at the subject, half press the shutter button to compose/ focus, then full press to take the photo. Or just push the shutter button to get the image if the situation is suitable. ”M” is for manual focusing, you twist the ring on the lens to set the focus as you want then press the shutter button to get the shot. The focus is entirely up to you, the camera treats the lens as if it does not have a motor in it. Okay, that is mostly true, there are some very old lenses such as the version one 14mm f2.8 lens that can be set to override this setting and autofous anyway, but Fujifilm has not used that design in many years. Note: There are many aids built into the camera to help you manually focus your shots. https://fujifilm-dsc.com/en/manual/x-t5/taking_photo/autofocus/ https://fujifilm-dsc.com/en/manual/x-t5/taking_photo/manual-focus/ As you can guess, this switch setting does not have to completely match the top dial settings, manual exposure settings are different than manual focusing, I am surprised you were told not to mess with it. p.s. You may want to pose your questions in the dedicated X-T5 section to get quicker responses from the X-T5 users.
