Does back button focusing work with the Fuji 14mm f2.8?
retrojim
 Share
I'm contemplating buying a 14mm 2.8 but I'm a back button focuser (can't stand half pressing the shutter for autofocus). Does back button focusing work on the 14mm if you have pulled the focus ring to manual? Or is the best way to do it to leave the focus ring clutch engaged on the 14mm and switch the body to manual?
Yes.  Unless it's a manual focus adapted lens, ANY FUJI lens will work w back button focus.  That is more of a camera function than a lens issue -- except, as I said if you use adapted lenses that are manual focus only or if you've pulled the ring on the lens to switch it to manual
Edited by jlmphotos
Loading...
 Share
