Lens
Hello and Happy New Year,
Im new to this forum and new into photography. I just picked up a XT3 with the kit lens 18-55 works really great, I'm not sure what kind Photographer I want to be lol can anyone help me in picking a good prime lens for an every day shoot instead of carrying a lot of lens around I would love any feed back on this.
thank you
  • 5 weeks later...
On 1/1/2022 at 2:41 PM, Olaf W. said:
Welcome to our forum. The 18-55 is a pretty good lens. You could use it to determine your preferred focal length and order a prime afterwards.
I agree w Olaf.  The 18-55 is an EXCELLENT lens that will allow you to explore what you like to shoot, and what you wish to accomplish going forward.  Fuji has many excellent lenses available - and several "Red Badge" lenses that are pricier.  I'd work with the 18-55 for a while as you determine what you like to do, and in what lighting you need/like to work in.  The lighting issue will determine if you need the faster aperture lenses or not.
Best of luck and let us know as you progress.
If you’re still pondering, I went through this last year 🙂.  I went with the 23mm f2.  I’ve owned a 35mm (50mm equivalent) before and really liked it but you often don’t have the space to back up.
If you’re not sure which prime, I think most would say that’s a good start.
FWIW, my reasoning for a prime was size basically as I have an X-30.  (Plus just hey, new lens 😂)
    • I do not use Flickr, so I do not know what their BB code is. All I did was copy the second link you provided, (starting at https: and ending at  _k.jpg — leave off the [img] and [/img] tags) and pasted it into the message. After a moment, a message popped up asking if I wanted to paste it as the image or as a plain link. I did this twice, the first time I had it paste in as the image and the second time as a link. Nothing fancy or tricky.
    • So do I just copy the BB code from flickr and paste it anywhere on the page like other forums or is there some other trick I need to perform to get it to post?
    • All software is the latest between camera and app. All settings are correct on camera. I have both lossless and uncompressed RAW files on the card in the camera. I have been up and down every reddit thread to no avail and am losing my mind… I’m doing all of the right things. It even sees my camera. It just doesn’t create the “drive” for it (see attached image screenshot).  Please Help!
    • Not sure how to delete threads, but I figured out what was wrong. In short, I was partially misunderstanding the view-mode's function. Also, the "+LCD Image Display" part requires that you have the Image Disp. setting set to anything but Off. Then it will display your last image on the LCD. If it's off, it's behavior will be exactly like the plain Eye Sensor setting.
