SS dial issue
RalfX-T4
Hi there, having assigned SS to back dial, randomly while in manual mode, my X-T4 does not change the shutter speed. I have to cycle through automatic mode or aperture priority and then back to full manual to make it work again, suggestions pls,? Best from Germany!
I got stuck on this for a while, but then worked out that you need to be in P Mode to be able to alter shutter speed.  Make sure the aperture ring on the lens is at 'A', and if you are also using the front dial to adjust aperture you need to make sure that's in the Auto position and not set to a specific aperture.
