ccguy
 Share
I'm trying to shoot with flash using a Godox 2.4GHz pair & strobe lights I've successfully used before; however, my only options in my flash menu settings are Manual & OFF. The button on the transmitter works with the receiver, but trying to use flash with the X-T4 has been unsuccessful. Are there any other settings that need to be enabled so it recognizes TTL/my hot shoe mount?
Loading...
 Share
    • By Gibby
      I'm shooting video with X-T4 on a gimbal, in continuous mode with face detect on.  If I try to change the focus point using the rear touch screen (pressing top right corner of screen until it gets to "AF", and then click on the desired focus point on the screen...it will refocus on that area, but only once.  As if it was switched to single focus mode.  The manual however, seems to indicate that the camera should remain in continuous focus mode and track that subject, which it doesn't.   I would like be able to click on a point using the rear screen and have the camera track in continuous focus.  Is this even possible?  Not clear in the manual.  tks.
    • By Gibby
      For stills, I'm using backbutton focus.  And I'm able to select the focus point and track it in continuous focus.  Works great.  But in video mode, I can't find a way to track an object - only a face using face detect.  The rear touch screen doesn't seem to work this way.  When I select a point, it behaves as single focus, even when the camera is set to continuous focus.  Also, I'm often using the camera on a gimbal and need to rely on the rear screen for setting the focus point.  To date, I've mainly had to use the X-T4 in manual mode for video which is disappointing.  Am I missing something?
    • By Théotim
      Hi all !
      After updating via app (1.23) my brand new x-t4 (work like a charm with 1.22 firmware) the EVF doesn't work at all now and if i try to switch to the EVF view every thing goes black and the camera get stuck like that forever... Even if i try to reboot it, the only option is to plug out/plug in the battery. Impossible to go back to the previous firmware (what a shame on a 2000€ camera). I'm very frustrated my camera is unusable... I update again the firmware with the classic SD option, the process finish the update without a problem but the problem persist cannot do anything with it now. If the camera go sleep... Stucked. If the eye sensor is activated for the EVF... Stucked. If i try to shutdown the camera... Stucked.
      Thank you in advance.
      Best regard.
    • By R3D
      Hi All,
      Hope that some encountered that problem before and can help.
      I get my X-T4 a few weeks ago with FW 1.17 and it seemed to work correctly but just for the sake of having most up-to-date version I updated to 1.22).
      After the update my fav view mode ([EYE SENSOR] + [LCD IMAGE DISP.]) is corrupted. It essentially keeps the LCD on whenever eye is away from EVF.
      Image preview is set 1.5 sec and is displayed correctly only on LCD screen. I set the LCD do info screen but it's not really how I'd like to have it working.
      I was hoping that 1.23 will fix it but unfortunately no change after yesterday's release.
      Thank you in advance!
      R.
    • By Danstall
      Hello,
      Totally new to photography. Got an XT4 as entry point wanting to learn.
      As a starting point I've just used everything on auto. Set stills to highest quality (but not using RAW).
      When I take film, it's awesome great quality, just what I'd expect. If I take a still of the same scene the results are totally different. Colours way less vivid, almost washed out and cropping loses quality quickly, like it's way lower res.
      I've scoured the internet for what I'm doing wrong - but I'm out of my depth very quickly. I was just expecting 'decent' images with everything auto. Most tutorials I've watched don't really explore everything auto.
      Using a Fujion XF 18-55mm Lens.
      Any guidance on where to start?
      Many thanks!
      PC
