Weirdest GO-Pro accessory
milandro
It’s really incredible what you can find for sale on line!
This is a rotating “ boom” to fit onto an helmet to wear on a bike and shoot yourself and or the place you are driving around with a Go-pro.
Even supposing that you are not going to be immediately stopped by the Police in any civilized place on earth read what they say.
Due to its safety design, it will automatically drop from your helmet when you have incident.
And there will be 0 damage to this device.
to the device maybe not........But not to you!
 I suppose that they wanted to say IF you have an accident but they may have written when because it is almost certain, that if you use one of this in an open road with traffic that you will have one!  :D
